| JRust |
May 25 2010, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Okay so I am putting a nice set of dual weber 40's on the LE. Going to get my break in miles done & drive it while I work on the FI stuff on the side. I get the basics of how to get them on. Was hoping someone could give me a nice step by step so I don't miss anything. Or put it on in the wrong order. I got the complete setup from Rich & he included everything needed except linkage which I picked up.
I allready installed the distributor & the intakes. I know I need to get my car to TDC & make sure my firing order is right. Okay lay it on me (IMG:style_emoticons/default/biggrin.gif) . In simple terms please (IMG:style_emoticons/default/blink.gif) |
| rhodyguy |
May 26 2010, 02:00 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jamie, if you did not install the phenolic intake gaskets used with the fi system, put some on before you button things up. installing them after the dial in will result in doing the procedure all over again. using the facet pump WILL require a fuel pressure reg and a fp gauge. if you purchase the cb pump, remove the metal canister connected to the pump with a short piece of fuel line and squeeze clamps. it's a fuel filter and will be a pain to change out which you will have to do eventually. i like the large white fi fuel filters with the same size fittings on both sides. note your jetting sizes prior to installing the carbs and write the numbers down in your cb weber book. MUCH easier now that later. if you approximated the same dist rotor positioning during the swap, the timing should be close enough to light the engine off.
JRust Installing dual carbs for the first time May 25 2010, 05:29 PM
type2man Bolting them on is pretty straight forward. The im... May 25 2010, 05:49 PM
JRust
Bolting them on is pretty straight forward. The i... May 25 2010, 07:33 PM
Here are pics
That fuel pump is going to drive yo... May 25 2010, 09:47 PM
JRust
Here are pics
That fuel pump is going to drive y... May 25 2010, 09:58 PM
jmill Buy the weber tech manual. It's worth the mon... May 25 2010, 06:53 PM
Kirmizi Get a rotary, Carter IIRC, but I can't remembe... May 25 2010, 11:38 PM
KaptKaos http://www.cbperformance.com/catalog.asp?ProductID... May 26 2010, 12:38 AM
Cevan Even if those are new carbs, they could probably u... May 26 2010, 05:20 AM
Gint You'd be a lot better off just getting the FI ... May 26 2010, 05:47 AM
dr914@autoatlanta.com Don't do it and ruin this "special" ... May 26 2010, 07:54 AM
tomeric914 Tech manual:
http://www.cbperformance.com/catalog... May 26 2010, 08:33 AM
computers4kids Jamie,
Seems like you should be able to buy a comp... May 26 2010, 08:58 AM
sean_v8_914 call me or PM. I'll try to help with your FI May 26 2010, 09:39 AM
sean_v8_914 dfghrehtr May 26 2010, 09:41 AM
sean_v8_914 fxhfdth May 26 2010, 09:42 AM
sean_v8_914 chfdzghd May 26 2010, 09:42 AM
sean_v8_914 bvngfxnfg May 26 2010, 09:43 AM
sean_v8_914 gcnbgfn May 26 2010, 09:44 AM
sean_v8_914 gfngfdn May 26 2010, 09:44 AM
sean_v8_914 fdhfdh May 26 2010, 09:45 AM
sean_v8_914 fghjftrjtrj May 26 2010, 09:46 AM
sean_v8_914 this linkage set up is also common but not my favo... May 26 2010, 09:50 AM
sean_v8_914 dfrgfdgfd May 26 2010, 09:53 AM
McMark Sean, those drawings were you try to equalize ever... May 26 2010, 10:34 AM
Vacca Rabite :agree: I tried to draw it out the first time, an... May 26 2010, 11:11 AM
JRust Okay thanks for all the tips! I am holding off... May 26 2010, 02:49 PM
Okay thanks for all the tips! I am holding of... May 26 2010, 02:54 PM
McMark I'm extremely anxious to see what it was that ... May 26 2010, 02:53 PM
Dr Evil
I'm extremely anxious to see what it was that... May 26 2010, 03:07 PM
JRust
I'm extremely anxious to see what it was tha... May 26 2010, 07:57 PM
Rav914 Save the carbs. IF you get tired of spending week... May 26 2010, 03:03 PM
Lennies914 :popcorn: I have to admit, I was a little bummed t... May 26 2010, 08:04 PM
JRust Going with Carbs was always & only going to be... May 26 2010, 08:24 PM
Root_Werks Be very interesting to see what makes the FI work.... May 27 2010, 01:33 PM
Shade Tree Well, hopefully, Bruce will see this post. He lik... May 27 2010, 02:02 PM
sean_v8_914 not the measurements, just teh angles. its relativ... May 27 2010, 03:19 PM
Root_Werks These are good linkage pictures, what kind of link... May 27 2010, 03:44 PM
Root_Werks More of it, it's on my engine, haven't see... May 27 2010, 03:46 PM
computers4kids
More of it, it's on my engine, haven't se... May 29 2010, 09:17 AM
Root_Werks
More of it, it's on my engine, haven't s... May 29 2010, 11:34 AM
biosurfer1 looks similar to the one I just setup and I agree,... May 27 2010, 03:53 PM
Root_Werks
looks similar to the one I just setup and I agree... May 28 2010, 09:18 AM
sean_v8_914 shzfdg May 28 2010, 09:46 AM
Racer Chris
shzfdg
It just so happens that I have a special ... May 28 2010, 12:11 PM
gothspeed To the OP ......... I will take those horribel car... May 28 2010, 12:00 PM
biosurfer1 Sean...can you take a picture of your return sprin... May 28 2010, 12:17 PM
arkitect Jrust,
What size carbs, just wondering for my proj... May 29 2010, 06:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 12:54 AM |
