| DanT |
May 25 2010, 10:13 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
anyone have some pics of a stock muffler...
directly from above and also from below... one directly from the back would be great also... want to do some photoshop work on one with some ideas I have. thanks (IMG:style_emoticons/default/biggrin.gif) |
| McMark |
May 26 2010, 04:36 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
High temp BBQ paint has done well for me. If you have a new muffler, remove all the primer down to bare metal. If you have an old muffler, wire wheel all the rust scale, then treat with Metal Ready, then paint. Mufflers are more likely to die from the inside out, so the outer coating isn't the common point of failure as long as quality products and prep are used.
| EdwardBlume |
May 26 2010, 04:39 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
High temp BBQ paint has done well for me. If you have a new muffler, remove all the primer down to bare metal. If you have an old muffler, wire wheel all the rust scale, then treat with Metal Ready, then paint. Mufflers are more likely to die from the inside out, so the outer coating isn't the common point of failure as long as quality products and prep are used. Awesome. Thanks! |
DanT Stock 2.0L muffler May 25 2010, 10:13 PM
JimN73 Dan, I can only get one picture - from the bottom.... May 25 2010, 10:21 PM
DanT won't be at Sears....will be making a quick ru... May 25 2010, 10:30 PM
kkid How about these?
May 25 2010, 10:48 PM
DanT perfect, thanks :D May 25 2010, 10:53 PM
DanT thinking about this... :D
twin piped in this gene... May 26 2010, 11:33 AM
DanT ooppsy... :D May 26 2010, 03:20 PM
McMark Contact jgara962. He just pulled one of those off... May 26 2010, 03:23 PM
DanT thanks Mark.. I dropped him a PM.... :) May 26 2010, 03:35 PM
RobW In the pictures, what'd you use to treat / pre... May 26 2010, 04:31 PM
DanT Rob, the pic I am using is not my muffler.
I pla... May 26 2010, 04:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 04:51 AM |
