| RJMII |
May 27 2010, 09:23 AM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
What tire sizes are you running with your flares?
What wheels sizes? What offset and spacer combo are you using? How much space between the tire and the inside of the flare? How much space between the tire and the inner fender? What set of flares did you use? |
| zig-n-zag |
May 27 2010, 02:15 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
I want to use 911 turbo hubs for the front in an effort to eliminate
spacers, but don't know if that is a good thing. Scrub radius issue? Late 911 hub-centric rear hubs might increase the rear track over the early lug-centric ones, 1/4" difference? Ultimate wheel combo for me would be 944T 8x16 fronts, 911 9x16 rear, or 8's all around, but might take the easy way out and go with all 7's. I recall someone said the AA flares can't fit 9's without massaging them, and for the use of 8's up front as well. |
RJMII flares, tire widths, offset combos May 27 2010, 09:23 AM
gothspeed I will be using AA steel flares with Fuchs standar... May 27 2010, 10:21 AM
Dr Evil Poor form, Jim :jerk: :poke: May 27 2010, 10:53 AM
RJMII
Blame it on the pe... May 27 2010, 11:30 AM
This should be... May 27 2010, 11:49 AM
RJMII
This should b... May 27 2010, 12:38 PM
RoninEclipse2G He didn't ask what he SHOULD run, but rather w... May 27 2010, 12:53 PM
jhadler Alright, I'll be the first to actually answer ... May 27 2010, 01:06 PM
Dr Evil Just giving you a hard time, Jim :) May 27 2010, 01:42 PM
mepstein What tire sizes are you running with your flares? ... May 27 2010, 02:36 PM
plays with cars
Ultimate wheel combo for me would be 944T 8x16 fr... May 27 2010, 09:55 PM
Elliot Cannon 275/40/17 tires. 11 inch wide rims. Zero off... May 27 2010, 10:55 PM
RJMII :bump: May 29 2010, 05:55 PM
J P Stein At some point I've run all kinds of combos.
Pr... May 30 2010, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 05:11 PM |
