| d914 |
May 26 2010, 06:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
Im looking to pop the doors off,, Two pins in the hinges,,,,,,,hit them with a big hammer and punch or unbolt them...
also the door stay at pillar....?? |
| pnewman |
May 28 2010, 08:17 PM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
I don't recommend trying to remove the hinge pins. only the door stop / keeper stay pin. You may damage the door sheet metal trying to remove the lower hinge pin. the bolts work fine as he said. Take a pencil and mark the corners of the hinges both on the top and on the bottom hinge to aid in alignment upon re-installation.
Good luck. ...also a second set of hands as well as the milk crate (preferably a plastic one or a metal one with a towel) to pad the top of the crate will help lower the chances of damaging the door during the process. |
d914 quick question: door removal May 26 2010, 06:34 PM
Spoke Take the 3 bolts off the top hinge and bottom hing... May 26 2010, 06:44 PM
d914 thanks May 26 2010, 06:55 PM
computers4kids If your door gaps are good, drill a small hole thr... May 28 2010, 08:31 PM
jaxdream Personally , if I were taking them off and remount... May 29 2010, 08:03 AM
rsrguy3 What about the pin puller/slide hammer? That seems... May 29 2010, 08:21 AM
J P Stein Those hinge pins are right up there with an rear a... May 29 2010, 09:08 AM
jaxdream Is there room to get a drill with what ever size d... May 29 2010, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 04:05 AM |
