kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
Replacing the ball joint on my early style (split end) 911 strut. The PO simply (and wrongly) put a "regular" bolt all the way through the BJ retaining hole with a nut on the end. As I now insect the threads on one side of the hole, they look rusty and may just be gone. My first impulse is to "chase" the threads and see if they are still there...still usable. Should I first soak them with something like PB Blaster? Then, should I use a correctly threaded bolt to "chase " the threads or use something else?
If the treads are gone, can I use a helicoil in that area, and can it be done with the strut on the car? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Actually, Slits be wrong. You clean the threads with a thread chaser. It will remove only the barest minimum of metal, and will (more or less) reform the threads. The less metal removed the better chance you have of ending up with usable threads.
As for drilling the hole straight, you come in from the unthreaded side and you'll have the correct alignment for the insert. As for the caliper mounting spacing, you measure the centerline of the 2 mounting holes, or the corresponding edges, which is easier. HOWEVER, and I've said this before, you MUST check the fit of the ball joint BEFORE you spend any time trying to fix the bolt hole. If the joint drops right in after any burrs are removed, the strut is junk. The ball joint will be loose in there no matter how hard you wish it weren't. There is NO FIX. Well, maybe you could get it metal sprayed and bored to size, but you could probably buy a brand new strut for less money. The Cap'n |
Lo-Fi Version | Time is now: 4th July 2025 - 12:16 PM |
