> flares, tire widths, offset combos, what are yours?
RJMII
post May 27 2010, 09:23 AM
Jim McIntosh
What tire sizes are you running with your flares?
What wheels sizes?
What offset and spacer combo are you using?
How much space between the tire and the inside of the flare?
How much space between the tire and the inner fender?
What set of flares did you use?
J P Stein
post May 30 2010, 08:57 AM
Irrelevant old fart
At some point I've run all kinds of combos.
Presently.....well, you don't want to go there. (IMG:style_emoticons/default/biggrin.gif)
The front end was interesting. At one point I fit a 10 X 16 wheel with a 10 slick.
The backspace was 5 1/2 inches. It required the dust cover of the front shock to be removed. I do some testing for clearance.......full compression of the suspension and lock to lock on the steering and adjust the bodywork to suit....no rubbing allowed.
The above didn't work out well. The wide wheels gave me around 3 (+?) inches of scrub radius giving an un-curable push....oh well.......but it fit with my hand hammered flares. Now there are 8 inch wheels up there (5 inch backspace) and the push is gone with the scrub radius decreased by 1 inch......who'da thunk it?
There's a lesson here for those wanting to run spacers up front.
The rear is much more straight forward. Again the 10 X 16 wheels with a 5 inch backspace. The straight side 10 slicks have about 3/4 inch clearance to the inner fender....enough if I keep at least 19 psi in the tires.......I got the big black marks on the inners at 18 psi *once*.
- Lo-Fi Version Time is now: 15th March 2026 - 05:13 PM
