| poorsche914 |
May 30 2010, 09:21 AM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
The seller of this ECU has no idea what year it is from or what the number is. Did the different model ECUs have a different color sticker? Seems I have seen green and maybe gray. Is there a chart or something posted somewhere with this info?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1275232898.1.jpg) |
| Tom_T |
May 30 2010, 09:51 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
The seller of this ECU has no idea what year it is from or what the number is. Did the different model ECUs have a different color sticker? Seems I have seen green and maybe gray. Is there a chart or something posted somewhere with this info? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1275232898.1.jpg) Part no. is showing below the Bosche on the red sticker, so see if you can do some CSI forensics to pull/coax out the full part no., then check that against the p/n in the 914 PET (free download pdf parts catalog from the Porsche website at Classics section). ECU's vary by engine & model year, won't run properly with wrong ECU on your 74 2.0 & won't work one from another without a complete EFI change - & you'll want to keep your 74 2.0 D-jet true to LE configuration, or risk losing big bucks in the value of it once restored/repaired. |
| poorsche914 |
May 30 2010, 11:50 AM
Part no. is showing below the Bosche on the red sticker, so see if you can do some CSI forensics to pull/coax out the full part no., then check that against the p/n in the 914 PET (free download pdf parts catalog from the Porsche website at Classics section). ECU's vary by engine & model year, won't run properly with wrong ECU on your 74 2.0 & won't work one from another without a complete EFI change - & you'll want to keep your 74 2.0 D-jet true to LE configuration, or risk losing big bucks in the value of it once restored/repaired. Thanks, Tom. Have no fear I will be putting the correct ECU in the car. Just have to find one (IMG:style_emoticons/default/dry.gif) This one is for sale so I do not have it to do any CSI work (IMG:style_emoticons/default/smile.gif) I have never had reason to check into it before but remembered seeing different color stickers on different ECU models - so I simply wondered if anyone knew for sure if that is the case. SOT but a question for you, Tom: concerning my LE, what about things that are "upgrades" or a slightly different way of doing something? Things such as replacing front and rear trunk springs with shocks or using non-stock hinge pivots on the rear rather than the weld on pieces. Is this any different than upgrading the torsion bars or sway bars to aftermarket items? Thanks for your expertise. |
poorsche914 ECU i.d. please May 30 2010, 09:21 AM
detoxcowboy you can run the 75-76 2.0 ecu in your '74 too.... May 30 2010, 10:41 AM
poorsche914
you can run the 75-76 2.0 ecu in your '74 too... May 30 2010, 11:58 AM
detoxcowboy :confused: if it helps you decide to buy, my 74 2... May 30 2010, 10:45 AM
roadster fan Hello,
The part number may be on the circuit boar... May 30 2010, 10:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:36 AM |
