| rohar |
May 30 2010, 09:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Car's getting a water cooled swap. I'm in the process of cleaning up/repainting almost everything. When all is done, it'll receive an entirely new electrical harness. Is there a reason I shouldn't take a set of face cutters to the existing harness and go nutz?
[edit] just to clarify, this is the chassis harness, the engine harness went with the engine |
ClayPerrine
Car's getting a water cooled swap. I'm i... May 31 2010, 03:24 AM
rohar Ok, I obviously didn't explain the extent of w... May 31 2010, 08:42 AM
markb IIRC, some of the connectors are hard to get. I wo... May 31 2010, 10:55 AM
McMark You can pull the entire harness out intact in abou... May 31 2010, 12:36 PM
Cap'n Krusty
You can pull the entire harness out intact in abo... May 31 2010, 12:39 PM
kg6dxn If you are going to rewire your car. Please remove... May 31 2010, 01:34 PM
rohar There's so much new gear going into the car th... May 31 2010, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th September 2026 - 03:09 PM |
