over analyzing trunk spring rollers, plastic, brass, alu? |
dem |
Jun 5 2010, 07:37 AM
Rusty Member Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California |
Mine are cracked. Looks like there are 3 choices, all pretty much around the same price!
Do I care? I'm almost tempted just to go with plastic, since that is what the factory used and as far as I can tell they have survived 37 years. If metal is reaaaaaaaly better, do I care about aluminum or brass? Let's see some passionate, religious debate about my trunk rollers. Choices, they paralyze me! (IMG:http://www.914world.com/bbs2/uploads_offsite/www.haphazard.com-11334-1275745074.1.jpg) |
Katmanken |
Jun 5 2010, 03:34 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
They are all the aftermarket design and have a bigger rotating bearing surface which is good.
My choice would be: Drop the aluminum as a choice. Aluminum makes a crappy bearing and galls. Now it's down to brass and plastic..... If the brass is an oillite bearing, I'd go with that. No oillite, then you need grease so switch to lubricious plastic. Lubricious plastic needs no oiling and in order of choice: 1. Delrin, and 2 , Nylon. Actually delrin makes a nice slick forever bearing that needs no lube, never wears, etc and may trump oilite which needs an occcasional oiling.... |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:56 AM |
