Brake fluid leaking at bleeder valves., Damn near all of them!! |
rjames |
Jun 6 2010, 06:29 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/headbang.gif) The saga continues. I know I have another thread started regarding my brake bleeding hell, but started a new thread since it's a specific question.
Rebuilt calipers. Each caliper has at least one bleeder valve that is leaking. All four of them are leaking at the bleeder at the top of the caliper, possibly lower ones to, but with the amount of fluid coming from the top and dripping down past the lower bleeder, it's hard to tell. I don't want to over tighten them, but they are very snug and still leak. To the point where the calipers drip if I pump the brakes. This is probably why I can't get a totally firm pedal. It's definitely not helping. Before I put the calipers on the car, I asked here if I needed to put anything on the threads and I received a big 'NO' from someone. Was this correct advice, or should I have put something on the threads to keep them from leaking? |
jsaum |
Jun 6 2010, 09:35 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I bought the speed bleeders and am happy with them, it makes bleeding the system a lot easier if there is such a thing. I give them about a one eighth turn past snug.I would pull one and check the treads against one of the old ones to see if they have a different pitch. Also check the end of the seats to make sure they're seating properly. If you see marks of heavy scoring on them you might have a pitted seat surface on the calipers.
Lo-Fi Version | Time is now: 9th June 2024 - 06:52 PM |
