What type of 911 caliper? I believe they are "A" calipers, Where are the part numbers? |
wallys914 |
Jun 6 2010, 09:39 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I swapped to a 911 brake setup and never attempted to look at the part number on the caliper, now I want to purchase pads for it, and since the car is on jack stands in the rear with the engine hanging I can't lift the front and pull off the front wheels.
I can see a 233 on the outside of one and 290 on the other caliper, a 30 on the inside of one? I have no idea what these mean? Where is a part number on the calipers? I will post pics in a few... |
Eric_Shea |
Jun 6 2010, 09:58 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I think it says ATE. (IMG:style_emoticons/default/wink.gif) None of that numbers stuff means anything, just casting numbers etc.
Here's how you can tell: * M9 Fasteners with a Ribe R6 head and "14mm Nuts" = A-Caliper * Fluid Inlet at the base of a widow's peak in the back = A-Caliper * The heaviest caliper ATE ever made for a 911 = A-Caliper (IMG:style_emoticons/default/biggrin.gif) * M8 Fasteners with a Ribe R8 head and 13mm nuts = M-Caliper * Fluid Inlet on the side with a banjo fitting = M-Caliper (if it has the13mm nuts) A-Calipers take AP45 Pads (from Porterfield) M-Calipers take AP31 Pads |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:18 AM |
