phillstek |
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None ![]() |
I really want to fix the shift linkage once and for all (ha) and need help.
Box is tail shift and was rebuilt and many of the bushes have been replaced. I have solid mounts at box and sport mounts at front. Part of the reason I put the car away 11 years ago was the fact that the linkage required constant adjustment to get all ratios (4th/5th especially). I am considering all options, including 915/G50 conversion if I have to. All advice would be gratefully recieved. Thanks, Phil |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
To convert a tailshift to a sideshift, you need:
Tail cone from a side shifter (not needed but nice)** Shift console for side shifter** Shift rails for side shifter (they're shorter)** Gasket kit** '73 up engine bar '73 up bar mounts '73 up motor mounts (both the rubber and the steel ones that mount to the motor) Side shifter shift lever Side shifter front bar Side shifter rear bar Firewall conversion bushing ** can eliminate these if you buy a sideshifter tranny complete. |
Lo-Fi Version | Time is now: 6th July 2025 - 07:57 PM |
