| kenshapiro2002 |
Jun 15 2010, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
OK...so I had to tear the left front strut out for replacement, and drained out the brake lines on that side. After I get the new strut in, I'm gonna take it to a local Porsche wrench for a front end alignment and to have him check out my work in securing the struts, ball joints, tie rod ends, etc. I'm sure I did a "bang up" job, but figure I'll let an expert check out my work for any uck fups. When I bleed the line on the front left side because of my work, do I need to do all four corners (hey...haven't bled brakes in 30 years)?
I have "M" calipers off of a 911 up front. Any tricks or special "need to knows" about bleeding these things? Is it easier to buy out of the Mighty Vac thingamajigees? |
| john rogers |
Jun 15 2010, 07:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I would recommend a pressure bleeder instead of a vacuum bleeder as they are worth their weight in gold when doing brake bleeding. In the future, try covering the opening of the brake reserviour with some plastic baggy and screwing the cap back on and fluid will barely leak out if a line is opened.
kenshapiro2002 Brake Bleeding Questions Jun 15 2010, 07:20 PM
kenshapiro2002 Damn...what a great idea!
Why pressure vs. va... Jun 15 2010, 08:18 PM
Spoke Another key to keeping fluid in the reservoir and ... Jun 15 2010, 08:17 PM
kenshapiro2002 You mean another human being? I'll probably be... Jun 15 2010, 08:20 PM
Vacca Rabite Ken, get a pressure bleeder. they cost ~$50,... Jun 16 2010, 06:08 AM
kenshapiro2002 Will any of them fit the 914's reservoir for s... Jun 16 2010, 07:43 AM
6freak if ya got the car off the ground,why wouldnt you d... Jun 16 2010, 07:23 AM
type47 :agree: to bleed all 4 corners. Old brake fluid wi... Jun 16 2010, 07:44 AM
URY914 If the fluid is fresh, you can only bleed the one ... Jun 16 2010, 07:51 AM
kenshapiro2002 Yeah, but it works when they do it to me...jewish ... Jun 16 2010, 08:00 AM
type47 my error Jun 16 2010, 08:04 AM
kenshapiro2002 Yeah...didn't say "the" brakes hadn... Jun 16 2010, 08:14 AM
URY914 I was just in the barber shop and some guy was com... Jun 16 2010, 09:16 AM
kenshapiro2002 Of course...if he's leaking enough, it's a... Jun 16 2010, 09:19 AM
underthetire I'm sure all those fancy bleeders are super ni... Jun 16 2010, 09:35 AM
kenshapiro2002 Don't see any way for suction...how's it w... Jun 16 2010, 09:52 AM
underthetire Just hook it to the bleeder and pump the brakes sl... Jun 16 2010, 10:07 AM
6freak Like they say in the classic`s ,there is no fr... Jun 16 2010, 12:37 PM
corsepervita
... Jun 16 2010, 01:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:48 PM |
