> Brake Bleeding Questions
kenshapiro2002
post Jun 15 2010, 07:20 PM
OK...so I had to tear the left front strut out for replacement, and drained out the brake lines on that side. After I get the new strut in, I'm gonna take it to a local Porsche wrench for a front end alignment and to have him check out my work in securing the struts, ball joints, tie rod ends, etc. I'm sure I did a "bang up" job, but figure I'll let an expert check out my work for any uck fups. When I bleed the line on the front left side because of my work, do I need to do all four corners (hey...haven't bled brakes in 30 years)?
I have "M" calipers off of a 911 up front. Any tricks or special "need to knows" about bleeding these things? Is it easier to buy out of the Mighty Vac thingamajigees?
underthetire
post Jun 16 2010, 10:07 AM
Just hook it to the bleeder and pump the brakes slow. It's like the old guys using glass jars. The loooong hose method works well to, same concept, I just like knowing fresh fluid is going to all 4 corners.
kenshapiro2002   Brake Bleeding Questions   Jun 15 2010, 07:20 PM
john rogers   I would recommend a pressure bleeder instead of a ...   Jun 15 2010, 07:32 PM
kenshapiro2002   Damn...what a great idea! Why pressure vs. va...   Jun 15 2010, 08:18 PM
Spoke   Another key to keeping fluid in the reservoir and ...   Jun 15 2010, 08:17 PM
kenshapiro2002   You mean another human being? I'll probably be...   Jun 15 2010, 08:20 PM
Vacca Rabite   Ken, get a pressure bleeder. they cost ~$50,...   Jun 16 2010, 06:08 AM
kenshapiro2002   Will any of them fit the 914's reservoir for s...   Jun 16 2010, 07:43 AM
6freak   if ya got the car off the ground,why wouldnt you d...   Jun 16 2010, 07:23 AM
type47   :agree: to bleed all 4 corners. Old brake fluid wi...   Jun 16 2010, 07:44 AM
URY914   If the fluid is fresh, you can only bleed the one ...   Jun 16 2010, 07:51 AM
kenshapiro2002   Yeah, but it works when they do it to me...jewish ...   Jun 16 2010, 08:00 AM
type47   my error   Jun 16 2010, 08:04 AM
kenshapiro2002   Yeah...didn't say "the" brakes hadn...   Jun 16 2010, 08:14 AM
URY914   I was just in the barber shop and some guy was com...   Jun 16 2010, 09:16 AM
kenshapiro2002   Of course...if he's leaking enough, it's a...   Jun 16 2010, 09:19 AM
underthetire   I'm sure all those fancy bleeders are super ni...   Jun 16 2010, 09:35 AM
kenshapiro2002   Don't see any way for suction...how's it w...   Jun 16 2010, 09:52 AM
underthetire   Just hook it to the bleeder and pump the brakes sl...   Jun 16 2010, 10:07 AM
6freak   Like they say in the classic`s ,there is no fr...   Jun 16 2010, 12:37 PM
corsepervita   I would recommend a pressure bleeder instead of ...   Jun 16 2010, 01:32 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:39 PM
