windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,863 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
This "73 1.7 needs new rear springs. Please recommend what & where to buy. Thanks very much.
(IMG:style_emoticons/default/bye1.gif) Attached File(s) ![]() |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
the 140s are a good compromise spring...a little more firmness compared to the 100s and also they are shorter so you can lower the car a bit... (IMG:style_emoticons/default/biggrin.gif)
It also depends on the shocks you are pairing them with...if you are using old worn out shocks, then expect the ride to be pretty poor no matter what you do. |
Lo-Fi Version | Time is now: 17th June 2024 - 02:44 AM |
