Oil Question, OK to Use Synthetic 5W 30? |
EdwardBlume |
Jun 23 2010, 09:51 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I don't want to stir up the oil debate but....
The only Royal Purple I found at FLAPS is 5W 30.. is this OK to use on a 2056 FI? And how many quarts go in? With a non started motor, should I pour some in the oil filter too? |
yeahmag |
Jun 23 2010, 09:57 AM
Advanced Member Group: Members Posts: 2,423 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Why not just order some Brad Penn Break-In Oil and know it's right? I had problems priming mine with oil in the filter and a fresh motor. The latest information suggests *no* oil in the filter actually helps prime and builds pressure faster.
Not sure how far you are from Pasadena, but I do have about 6 quarts of BP 30w Break-In oil... |
EdwardBlume |
Jun 23 2010, 10:07 AM
Why not just order some Brad Penn Break-In Oil and know it's right? I had problems priming mine with oil in the filter and a fresh motor. The latest information suggests *no* oil in the filter actually helps prime and builds pressure faster. Not sure how far you are from Pasadena, but I do have about 6 quarts of BP 30w Break-In oil... Thanks. The motor is already broke in with about 2K miles. It was running RP so I figured I'd keep the same program. The only issue is the weight... |
Lo-Fi Version | Time is now: 11th June 2024 - 01:35 PM |
