> Gulf Blue Build Thread, The build never ends
PanelBilly
post Jun 25 2010, 10:56 PM
I managed to find some photos that we had thought were lost. This doesn't take me all the way back to the start of the project, but I've decided to start the photo story of the project.
April 2004
The 2 liter engine I sold with the fuchs
PanelBilly
post Jun 27 2010, 10:03 PM
I don't have a lot of photos showing the flare installation, but trust me I spent way too many hours attempting to line everything up. I think tacking the flare to the body and then cutting the old part out with an air saw is the best method because it leaves an equal gap for welding.
PanelBilly   Gulf Blue Build Thread   Jun 25 2010, 10:56 PM
PanelBilly   Here's some shots of the damage that I found w...   Jun 25 2010, 11:01 PM
PanelBilly   The car was walnut blasted and sealed with primer....   Jun 25 2010, 11:08 PM
PanelBilly   I enrolled in autobody at the local CC and stared ...   Jun 25 2010, 11:14 PM
PanelBilly   Flares from AA arrived and I started the process o...   Jun 25 2010, 11:33 PM
PanelBilly   I cut away the rust holes on the inside of the sai...   Jun 26 2010, 09:08 AM
PanelBilly   After I welded I recoated with POR. I purchased so...   Jun 26 2010, 09:13 AM
PanelBilly   Next came the installation of the Engman kit. I di...   Jun 26 2010, 09:24 AM
914rat   When do we get to the Gulf Blue part?Looks like yo...   Jun 26 2010, 10:49 AM
FourBlades   Great pictures! I have really enjoyed watchin...   Jun 27 2010, 05:48 PM
jimkelly   have you checked your door gaps since welding in t...   Jun 27 2010, 09:03 PM
PanelBilly   This is a retro thread. I'm going back and sho...   Jun 27 2010, 09:39 PM
PanelBilly   I don't have a lot of photos showing the flare...   Jun 27 2010, 10:03 PM
PanelBilly   The entire car was sprayed with fill coat and bloc...   Jun 27 2010, 10:09 PM
PanelBilly   The bottom was coated with Poline. Later I had it ...   Jun 27 2010, 10:16 PM
PanelBilly   Here come color, trunks and interior first. ...   Jun 27 2010, 10:27 PM
PanelBilly   Taping off trunks and interior. Trusty helper who ...   Jun 27 2010, 10:30 PM
PanelBilly   And now for body color (the first attempt at findi...   Jun 27 2010, 10:32 PM
PanelBilly   And the color is on (but not for long!)   Jun 27 2010, 10:34 PM
PanelBilly   The color I used was from a code that matched a po...   Jun 27 2010, 10:42 PM
rjames   The color I used was from a code that matched a p...   Jun 27 2010, 11:22 PM
PanelBilly   Resanded the color off the car, resealed it, color...   Jun 29 2010, 10:26 PM
PanelBilly   The /4 engine mounts were removed the /6 welded in...   Jun 29 2010, 10:35 PM
PanelBilly   In the last group of photos, you can see part of t...   Jun 29 2010, 11:06 PM
PanelBilly   The body wire harness was rewrapped in the best el...   Jun 29 2010, 11:31 PM
PanelBilly   The headlights were redone and installed   Jun 29 2010, 11:35 PM
PanelBilly   The air distribution was installed   Jun 29 2010, 11:38 PM
PanelBilly   Some odd parts were painted   Jun 29 2010, 11:41 PM
Eddie914   Billy, The teener looked great when you had the g...   Jun 29 2010, 11:43 PM
PanelBilly   The only mechanical I've completed to date is ...   Jun 29 2010, 11:50 PM
Root_Werks   :drooley:   Jun 30 2010, 08:47 AM
john deb   Hey Billy We had fun looking at the work you have ...   Jul 25 2010, 05:34 PM
PanelBilly   I should have taken some photos, but this weekend ...   May 12 2013, 10:43 PM
aircooledtechguy   I'm really glad to see you moving forward on y...   May 13 2013, 08:12 PM
PanelBilly   I finished assembling the drivers door and mounted...   Jun 3 2013, 10:20 PM
mepstein   I finished assembling the drivers door and mounte...   Jan 19 2014, 08:19 PM
PanelBilly   Tonight I got the passenger door panel attached. L...   Jun 7 2013, 09:46 PM
JRust   Progress is always good. Even when it involves rem...   Jun 7 2013, 10:11 PM
Daiberl   Billy, let me know if you need a helping hand agai...   Jun 7 2013, 10:22 PM
PanelBilly   I got the interior trim for the roll bar screwed i...   Jun 19 2013, 10:59 PM
jaxdream   Dadgum , that do look great !!! Not to...   Jun 20 2013, 07:25 AM
mepstein   Dadgum , that do look great !!! Not t...   Jun 20 2013, 07:32 AM
PanelBilly   I put on plastic, but I had a metal set in my gara...   Jun 20 2013, 08:11 AM
Socalandy   Looks Awesome!!! Nice work :D   Jun 20 2013, 09:25 AM
PanelBilly   With Jurgen's help, I figured out that I neede...   Jun 21 2013, 10:18 PM
PanelBilly   I got the lower seal for the targa installed (than...   Jun 21 2013, 10:27 PM
PanelBilly   Installed the vertical trim on the roll bar and th...   Jun 21 2013, 10:34 PM
rdauenhauer   :lol: yer killin me   Jun 21 2013, 10:54 PM
PanelBilly   I read too many stories about how the sound of the...   Jul 22 2013, 08:42 PM
PanelBilly   I installed the seat belts, although i know I...   Jul 22 2013, 08:46 PM
PanelBilly   I edged the rear window with black gorilla tape wh...   Jul 22 2013, 08:48 PM
PanelBilly   Seats were installed   Jul 22 2013, 08:51 PM
PanelBilly   I got this crazy idea to make my own fabric dash f...   Jul 22 2013, 08:54 PM
PanelBilly   Here's the basketweave   Jul 22 2013, 09:29 PM
PanelBilly   I got the glove box door installed now and the spr...   Aug 6 2013, 11:19 AM
PanelBilly   its much easier if the vents are removed   Aug 6 2013, 11:21 AM
PanelBilly   I installed new rubber seals in the front trunk an...   Oct 20 2013, 04:27 PM
PanelBilly   I also go the steering wheel installed   Oct 20 2013, 04:33 PM
Evil Older Brother   I also go the steering wheel installed Nice wh...   Oct 20 2013, 05:12 PM
CptTripps   Looking great man!   Oct 20 2013, 05:13 PM
Daiberl   Nice progress! I will try to come down in the ...   Oct 20 2013, 05:39 PM
PanelBilly   I needed the retainer clip that holds the fog ligh...   Jan 19 2014, 08:13 PM
CptTripps   Just curious: What did it cost to have Line-X spra...   Jan 23 2014, 09:19 AM
OU8AVW   On the same note, what product did you use on the ...   Jan 23 2014, 12:25 PM
CptTripps   Mike: look on eBay for a roll of "fat mat...   Jan 24 2014, 07:16 AM
aircooledtechguy   Billy; Glad to see you making progress again on t...   Jan 24 2014, 10:45 AM
CptTripps   I never even thought of using it on my roof. Inter...   Jan 24 2014, 02:56 PM
aircooledtechguy   I never even thought of using it on my roof. Inte...   Jan 24 2014, 10:17 PM
PanelBilly   Made the down payment on the machine work for the ...   Jan 24 2014, 07:03 PM
CptTripps   I'd love to do the assembley, but after invest...   Jan 24 2014, 10:17 PM
PanelBilly   Let's see if this works. Its the 3D of my pist...   Feb 15 2014, 11:46 AM
saigon71   Man you do nice work! :beer2: What's t...   Feb 15 2014, 02:14 PM
Evil Older Brother   Nice Billy. Using the old art skills again. I s...   Feb 15 2014, 02:53 PM
PanelBilly   I can't take any credit for this. It's the...   Feb 15 2014, 03:58 PM
PanelBilly   Little jobs done, but every step is one closer Ne...   Feb 15 2014, 05:36 PM
rick 918-S   So when's the debut?   Feb 15 2014, 07:25 PM
PanelBilly   Eta is April. Then comes install and tuning.   Feb 15 2014, 07:49 PM
jm993rs   Very good work !! :headbanger:   Feb 16 2014, 06:58 AM
cary   Nice work ................   Feb 17 2014, 12:07 AM
PanelBilly   I got my message today that Webcam is shipping my ...   Feb 18 2014, 10:48 PM
bulitt   You deserve alot of credit for sticking with this ...   Feb 19 2014, 06:30 AM
PanelBilly   I can use help. Willing to feed you and keep the f...   Feb 19 2014, 03:42 PM
Daiberl   I can use help. Willing to feed you and keep the ...   Feb 24 2014, 04:31 PM
PanelBilly   Today I stopped at Triad to pick up my headers and...   Feb 20 2014, 07:52 PM
PanelBilly   Today I pulled the stack out of the transmission t...   Feb 22 2014, 07:27 PM
PanelBilly   I need to get the tires pulled off, so the wheels ...   Feb 23 2014, 03:17 PM
OU8AVW   I have a set of wheel caps off some phone dials, m...   Feb 25 2014, 01:37 PM
PanelBilly   I got my distributor back from Jerry Woods. Its be...   Feb 26 2014, 04:47 PM
JRust   Looking good! So great to see this build comin...   Feb 26 2014, 05:44 PM
Johny Blackstain   :popcorn: :thumbsup:   Feb 27 2014, 09:37 AM
PanelBilly   Got the re-chromed fog light grills back and mount...   Mar 1 2014, 04:56 PM
PanelBilly   The flywheel from Kennedy showed up today. Now the...   Mar 3 2014, 03:56 PM
PanelBilly   Lots of stuff today! The diffusers that go bet...   Mar 5 2014, 09:22 PM
quadracerx   WOW... Everything looks great!! Ill give y...   Mar 5 2014, 10:44 PM
PanelBilly   I couldn't get much done this week. Work and S...   Mar 16 2014, 09:04 PM
PanelBilly   Lets see what showed up now.... Lower valve cover...   Mar 28 2014, 10:17 PM
r_towle   Great to see you working and painting again :) No...   Mar 29 2014, 07:06 AM
jaxdream   Will that shift rod work with a six ??? Jacck   Mar 29 2014, 07:11 AM
PanelBilly   Yes the Triadwest headers work with a stock shift ...   Mar 29 2014, 08:31 AM
jaxdream   :thumbsup: I asked cause I've seen pics of si...   Mar 29 2014, 09:51 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
