Oil change, valve and clutch adjustment, under 2 hours |
Cevan |
Jul 2 2010, 06:09 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I put another 500+ miles on my new engine and it was time for an oil and filter change and valve adjustment. I also pulled the sump cover for inspection and adjusted my clutch cable. None of the valves ended up needing an adjustment. I'm good for another 3000 miles. (IMG:style_emoticons/default/aktion035.gif)
It took me about an hour and 45 minutes start to finish. Not bad I think for a non-mechanic. (IMG:style_emoticons/default/beerchug.gif) |
realred914 |
Jul 3 2010, 10:04 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
new motor, I'd probably recheck them valves again before another 3000 miles (more like 500 again) to be on teh safe side. if they are still stable, then i say your golden. do a second oil change then also. that first round of break in oil did not get all drained out the first oil change, and it is surely full of residue. a second oil change will remove a lot more of that initial break in oil and grit.
have fun with the new motor, who built it? what compresiion ratio, valve sizes, cam? me i am thinking of a bigger motor asap as mine is bit the dust. is yours running stock d-jet ok? just want to get some ideeas if you can be of any help. thanks! |
Cevan |
Jul 3 2010, 10:44 AM
new motor, I'd probably recheck them valves again before another 3000 miles (more like 500 again) to be on teh safe side. if they are still stable, then i say your golden. do a second oil change then also. that first round of break in oil did not get all drained out the first oil change, and it is surely full of residue. a second oil change will remove a lot more of that initial break in oil and grit. have fun with the new motor, who built it? what compresiion ratio, valve sizes, cam? me i am thinking of a bigger motor asap as mine is bit the dust. is yours running stock d-jet ok? just want to get some ideeas if you can be of any help. thanks! I didn't mean my post to be boastful in any way. I was just psyched that I'm getting more proficient with this car stuff. As for the motor, I did a cam breakin and then changed the oil and filter and adjusted the valves. Then I drove it for about 125 miles and did another oil/filter change and valve adjustment. Then I went another 550 miles and did another oil/filter change and valve adjustment. My engine build link is in my signature. It's a 2056 with rebuilt stock 2.0 heads, a Raby 9050 cam, 9:1 compression, 40mm IDFs. Fun fun fun. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:00 PM |
