My Car Went Down This W.E., Flywheel Failure (Again) |
jfort |
Jul 5 2010, 01:13 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
Had a tooth out. I could hear a repetitive thump when starting and I knew it was a tooth missing. But, finally, this w.e. more teeth must have broken off and of course it stopped right where it won't engage with starter gear. Push started it and dropped it off at shop. I replaced flywheel about 6-7 years ago. My mechanic says it happens with 69-era 911's. High torque starter probably doesn't help.
914Sixer |
Jul 5 2010, 06:49 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What is wrong with replacing the .8 hp stock starter with the stock 911 (73-) 1.5 hp starter? Simple, easy and a direct bolt in.
campbellcj |
Jul 5 2010, 09:42 PM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
What is wrong with replacing the .8 hp stock starter with the stock 911 (73-) 1.5 hp starter? Simple, easy and a direct bolt in. That's what I'm using. Nothing at all wrong with it -- works great -- but heavier than the aftermarket "hi-torque" units and possibly more expensive (?) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:42 PM |
