> Okay CV Joint experts....Might be about to break them., what does a About to break Cv sound like?
budman5201
post Jul 2 2010, 11:46 PM
Yes my engine is SO much fun and addicting, but I dont know why i even take my car out when i am drenched from the heat on the way back home. (still 98 degrees here in az at 10 PM!) I am taking my time with the A/C system so thats not done for a few months.
Love the torque, but i think one of my Cv's is on its last life. I am getting a pretty good clunking noise that is exactly the pace of the spinning of the wheel at speed. About 20 mph all the way to ....well. 75 lets say. Its at the rear wheel, drivers side, sounds like on the outside inside the suspension arm where the cv bolts to the hub.
What does an about to break CV joint sound like?
charliew
post Jul 7 2010, 05:29 PM
The first thing I would check are the cv bolts. Jack it up and put stands under the arms and run it slowly after making sure it's not the bolts. You can apply a little load with the emergency brake to help similate the normal load.
I once parked one of my fieros from a rear clicking only to find months later it was the emergency cable hitting a partially sticking out wheel weight. It only happened on left slow turns when I discovered it. The cable was real new and it knocked the covering off in that spot.
- Lo-Fi Version Time is now: 17th July 2025 - 04:44 AM
