patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I might be interesting in taking out the engine of my car and swapping with something better sometime down the road in the future. Currently it's an old VW bus motor, no horsepower, some ok torque in 1st and 2nd, but nothing after that.
I did some searching, and came across a few threads - but are there any good previous threads or articles out there that touch on each engine option available to upgrade to in the 914? Cost, benefits, pros/cons, etc. I know there was a poll once asking which upgrade to do - but could not find it. Thanks! |
patssle |
Good stuff. What does the 3.2 Porsche engine weigh? Also, do you have to change transmissions with the 3.2, or can it handle that power?
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Good stuff. What does the 3.2 Porsche engine weigh? Also, do you have to change transmissions with the 3.2, or can it handle that power? I've run a 3.6L 993 motor in my 914 since 1999 and still use the 914 transmission, although with shorter gears. If I raced it a lot it would need more PM. But if you are smooth and respect the machine, that transmission will last a very long time. That said... A while back, I let a long-time friend drive my car. After he watched me do it for about 30 minutes (with instruction) I figured he would be kind to the car. Later in the day I arranged with another friend to let him drive her 993, a car he was considering for himself (not that one). He had a good time but never understood smooth. I truly think he wanted to, and thought he was at first, but... dang. He has owned British sports cars in the past, so at the minimum I expected decent lines. But he was very busy shifting too much. I finally had to relieve him of the con before he trashed my transmission. He couldn't understand light throttle and (relatively) synchronized shifts. Even if I factor in EXCITEMENT!!!!! and NERVOUS!!! it was too much. He'd never had that much power to modulate. I have two 915 transmissions and have never had to put one in because the 914 transmission just won't break! It's almost disappointing! I'll get over it. (IMG:style_emoticons/default/beerchug.gif) |
patssle |
I've run a 3.6L 993 motor in my 914 since 1999 and still use the 914 transmission, although with shorter gears. If I raced it a lot it would need more PM. But if you are smooth and respect the machine, that transmission will last a very long time. That said... I have two 915 transmissions and have never had to put one in because the 914 transmission just won't break! It's almost disappointing! I'll get over it. (IMG:style_emoticons/default/beerchug.gif) You know, that makes the 3.2 option a lot more temping. Same transmission, don't have to tear the car up for water cooling. Engine cost will up there though, but that's a lot of HP for the money. Though, I did read it might need oil cooling? |
BigD9146gt |
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand ![]() |
You know, that makes the 3.2 option a lot more temping. Same transmission, don't have to tear the car up for water cooling. Engine cost will up there though, but that's a lot of HP for the money. Though, I did read it might need oil cooling? 964/993 engines don't have H2O, thats 996 and up. Your correct on oil though, the 3.6 engines need an external oil cooler setup, whereas the 3,2 is much more plug and play with cooler onboard. |
Lo-Fi Version | Time is now: 4th July 2025 - 10:44 AM |
