patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I might be interesting in taking out the engine of my car and swapping with something better sometime down the road in the future. Currently it's an old VW bus motor, no horsepower, some ok torque in 1st and 2nd, but nothing after that.
I did some searching, and came across a few threads - but are there any good previous threads or articles out there that touch on each engine option available to upgrade to in the 914? Cost, benefits, pros/cons, etc. I know there was a poll once asking which upgrade to do - but could not find it. Thanks! |
patssle |
That's amazing that the weak little bus engine can be upgraded like that.
Can a ~60 hp bus engine be upgraded to the 2270? Or is that pushing it? |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,754 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
That's amazing that the weak little bus engine can be upgraded like that. Can a ~60 hp bus engine be upgraded to the 2270? Or is that pushing it? Sure, but at that point its just the case (assuming its in good condition) and the flywheel (assuming its in good condition) - and maybe the tin unless you are going to upright cooling. Everything else is swapped for new stuff. And the case will need clearancing on the internals or the crank and rods will impact it. That said, when I am done restoring my jeep, my next project will be to build a 2270 for my 914. Zach |
Lo-Fi Version | Time is now: 4th July 2025 - 11:02 AM |
