Clutch adjustmetn problem 74 six, mystery |
sixaddict |
Jul 10 2010, 09:54 AM
Senior Member Group: Members Posts: 811 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Long story but I need to eliminate solutions for readers.
74 914-6 3 liter Two track events ago clutch started acting funny and shifts were wierd so pulled off. CLashed gears ....so turned off ,put in gear and key started....after a few adjustments with what appeared t obe a stretched cable, removed and replaced clutch cable.....Could find no stretching in remove cable and was able to adjust to make it work but seemed to consume most of the adjustment to get clutch action. Chapter 2: Went home removed everything expecting bad pivot ball or clutch etc.....All ok. Chapter 3: Next track event trans issue but unrelated to clutch.....(Slider for 1st gear out of adjustment) so shop pulled all to go in and adjust. Upon reassembly and test drive wierd clutch issue resurfaced and standard assumptions disproved after everything was disassembled. Shop has ruled out pivot ball, pedal cluster etc., clutch tube.....and it is back apart without a clear culprit. Trying to help them get to root of issue in hopes someone has something to suggest. Thanks for anything that might be work investigating. Terry |
IronHillRestorations |
Jul 10 2010, 10:12 AM
I. I. R. C. Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd suggest very close inspection of the clutch tube at the fire wall. I've seen ones that were failing, but it wasn't easy to see it.
If it wasn't apart I'd say get it on a lift and have someone push the pedal while closely watching the firewall and then the clutch fork. I guess it's also possible that the diaphram spring has been sprung and it will never fully disengage, but I have never seen that first hand. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:40 PM |
