Spark Plug reading Help |
tornik550 |
Jul 26 2010, 09:32 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am in the process of tuning my carbs. I had been dealing with some significant rich running issues that I posted in a previous post. That issue is resolved. Now, I am able to drive the car however it seems to hesitate at cruising speeds (2500k rpm). Idle seems a little rough.
I am a novice at reading spark plugs. I am looking for opinions on this plug. The other plugs look the same except the white on the electrode only goes a little past the curve. I should note that the timing was a bit too advance and has been dialed back a slight bit. My guess- little too rich, too hot of spark plug and timing too advanced. Setup info- Dual weber 40 idf- recently sync'd idle jet- 60 mains-145 air correction jets- 200 emulsion tubes- f11 vents 32 Spark Plugs- NGK BP7ES Engine- 2.27l I should also note that I have a lot of spark plugs laying around. Doe anybody know if a NGK BP8ES is hotter old colder than BP7ES (think its colder). Attached thumbnail(s) Attached image(s) |
Mark Henry |
Jul 26 2010, 09:36 PM
Way to lean!
engine specs? |
tornik550 |
Jul 26 2010, 09:45 PM
Way to lean! engine specs? For my future reference- what makes you think too lean? I thought maybe a little rich because I had some black soot on the base ring. Engine Specs- 2.27l-recently rebuilt by local porsche builder using parts I provided. 78.5mm crank 96mm jugs 2.0l heads not sure of cam- told by PO was "a fairly aggressive webcam for carbs" whatever that means. I really should have checked prior to assembly. MSD 6al MSD blaster 2 coil bosch 050 dizzy What do you think I should change? |
Lo-Fi Version | Time is now: 1st June 2024 - 01:12 AM |
