| broomhandle |
Jul 27 2010, 09:47 AM
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
I have a 70 and a 71 which use the "easy to find fog light bulbs" looks like 72 or 73 they used a H3 bulb version. Is it just a unbolt and splice together the wires? or is there any conversion i can do to my originals? The goofy bulbs produce no light, and 1 side I can not get to come on.
| Tom_T |
Jul 27 2010, 11:32 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
I have a 70 and a 71 which use the "easy to find fog light bulbs" looks like 72 or 73 they used a H3 bulb version. Is it just a unbolt and splice together the wires? or is there any conversion i can do to my originals? The goofy bulbs produce no light, and 1 side I can not get to come on. IIRC - the usual suspects AA, Pelican, PP/Automotion (15% off coupon at their website right now BTW), SMC, etc. - most all carry the standard spec. & an up-wattage bulb (H3 I'm pretty sure) which will fit the stock OE 73 fog/driving lights, but will look the same. IIRC they're about 55w instead of 35w, but check the websites. You may need a relay for some of the higher output ones as well, &/or you may want to get the JWest foglight flash kit/relay to enable you to flash the fogs with the headlights down. You may also have a wiring leads &/or harness &/or bulb socket issue(s) with the side that won't come on - or maybe loose or corroded connections that needs cleaning & some Wurth connection oel/oil, & you may also be getting a voltage drop in the 37-38 year old wiring causing the low output - if it's all not just a case of weak/bad bulbs. The standard 7" sealed beams & H4s at 55/65w were pretty weak, but they also sell an H4 housing & 80/100w conversion - which requires a relay set-up added, but did wonders in my 88 Westy & I plan to do similarly in my 73 2L's resto. These all above can be done inconspicuously to keep it original for CW purposes. Good Luck! (IMG:style_emoticons/default/beerchug.gif) |
| broomhandle |
Jul 27 2010, 02:21 PM
I have a 70 and a 71 which use the "easy to find fog light bulbs" looks like 72 or 73 they used a H3 bulb version. Is it just a unbolt and splice together the wires? or is there any conversion i can do to my originals? The goofy bulbs produce no light, and 1 side I can not get to come on. IIRC - the usual suspects AA, Pelican, PP/Automotion (15% off coupon at their website right now BTW), SMC, etc. - most all carry the standard spec. & an up-wattage bulb (H3 I'm pretty sure) which will fit the stock OE 73 fog/driving lights, but will look the same. IIRC they're about 55w instead of 35w, but check the websites. Good Luck! (IMG:style_emoticons/default/beerchug.gif) The H3 will not go into the original 70/71 lights correct? dose anybody know what year they switched to H3 bulbs? and sorry if this is an illegal post in this section. |
| Tom_T |
Jul 27 2010, 04:13 PM
The H3 will not go into the original 70/71 lights correct? dose anybody know what year they switched to H3 bulbs? and sorry if this is an illegal post in this section. Don't worry about it - at worst one of the admins/moderators will move it to the garage forum, where you'll get so many different opinions that you'll think you're at a lawyers' convention! (IMG:style_emoticons/default/biggrin.gif) Here's some good info. on the OE lights - http://www.p914.com/p914_lenses_fog.htm I'm a bit confused as to what you're asking for, as I thought you were asking about a 73 or updating to that later light on a 70-71. IIRC the bulbs are different - but both types have higher output options, relay kits & the foglight flash kit works with any MY 70-76 IIRC. Make sure to download a free pdf Porsche 914 PET parts catalog from the Porsche website under their Classics section, so you can get proper bulb nos. for your particular MY & light, then you can look up other replacement bulbs from the lists at Hella, Bosch, OSRAM/Sylvania, etc. using their catalogs & online parts lists. |
broomhandle Fog Swap Jul 27 2010, 09:47 AM
underthetire My 73 had the funny bulbs to. I put the pilot ligh... Jul 27 2010, 09:58 AM
broomhandle
My 73 had the funny bulbs to. I put the pilot lig... Jul 27 2010, 10:01 AM
underthetire They go in the same spot, they look a little diffe... Jul 27 2010, 10:05 AM
broomhandle
The H3 will not go into the original 70/71 light... Jul 27 2010, 06:12 PM
Tom_T
[quote name='Tom_T' post='1348730' date='Jul 27 2... Jul 27 2010, 06:35 PM
914Sixer Somebody made a conversion kit to change factory o... Jul 27 2010, 02:19 PM
underthetire I'll only Add that the Pilots work awesome, an... Jul 27 2010, 02:55 PM
Tom_T Here are 2 of the 35w OEM Tungsten Fog Light Bulbs... Jul 27 2010, 08:24 PM
914Sixer The Euro cars had H-3 bulbs from the on set. US m... Jul 28 2010, 05:16 AM
Eric_Shea :agree: No H3's here... Nov 3 2010, 03:47 PM
Pat Garvey Guess I'm a little confused as to why you... Nov 4 2010, 06:27 PM
Eric_Shea http://www.914world.com/bbs2/uploads_offsite/sphot... Nov 9 2010, 10:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:26 AM |
