914's with 911 dash/gauges/interior, Let's see em! |
RiqueMar |
Jul 29 2010, 03:00 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
So many picture threads going around, so lets start another!
Time to show off guys! Let's see those crossover parts! |
Larry.Hubby |
Jul 31 2010, 09:45 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
Here's mine.
This is not a Getty dash, but not a total 911 transplant either. It's a '70 car, first converted to a '72 dash, then with a 911 instrument panel cut from a '78 SC and trimmed to be similar to the 914 panel mounted with the stock four screws. The top pad is a blend of an old 914 pad with the area above the panel cut out and that area from a 911 grafted in, then the gaps filled with foam-in-place material, the result sanded smooth, and finally upholstered in vinyl by Palo Alto Upholstery. I also replaced the steering column with one from a SC, and converted to the 911-type ignition switch and steering column lock using the front dash section and dash trim plates from a wrecked 914/6. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:59 AM |
