I want a welded steel roof, Probably as popular as the flu... Anyone do this? |
Corkus |
Aug 2 2010, 11:04 AM
Newbie Group: Members Posts: 22 Joined: 14-June 10 From: N. Calif & S. AZ Member No.: 11,834 Region Association: None |
I had a 914 in the 70's and liked the targa top back then. But in my middle age I have a solid dislike for convertible anythings, targa tops, sunroofs, convertibles, semi-convertibles or anything but a simple steel roof.
I also like the extra chassis stiffness a welded steel top will add. Here is a steel top but with a 924 sunroof. I don't get the sunroof but then I don't expect anyone to think a solid steel roof is a good idea either. Anyone weld a steel top on their 914? |
realred914 |
Aug 4 2010, 10:48 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
hows about adding steel stifeners under teh stock targa top? then you got he stiffness, plus the removable targa top only obstructed by some bracing? maybe a couple lentghs of 1 inch tubing form the two front to two rear conrers? maybe with some diaginals?
Bleyseng |
Aug 4 2010, 11:08 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
hows about adding steel stifeners under teh stock targa top? then you got he stiffness, plus the removable targa top only obstructed by some bracing? maybe a couple lentghs of 1 inch tubing form the two front to two rear conrers? maybe with some diaginals? Put in a cage if you want to stiffen it. The beauty of the steel roof its then a true coupe, quieter, stiffer etc plus the sunroof gives you about the same feel as the stupid targa top when its off. With the top off a 914 still doesn't have the feel of a convertible. They should've gone ahead with the 916 project with removable sunroofs, 2.4L sixes and flares. A 2.0L six was just too gutless and stark. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:09 PM |
