spedo drive in trans, leaky |
tomh |
Aug 8 2010, 10:06 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I want to stop the small amount of oil dripping from my spedo angle drive.
The o-ring and small seal were sent to me so i have the parts. do I just take out the holding screw and slide the barrel out?Will the whole shaft and gear come out?do i need gasket sealer on the barrel also.and how far will I have to jack up the back to stop the oil from flowing out? |
Tom_T |
Aug 8 2010, 12:38 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I want to stop the small amount of oil dripping from my spedo angle drive. The o-ring and small seal were sent to me so i have the parts. do I just take out the holding screw and slide the barrel out?Will the whole shaft and gear come out?do i need gasket sealer on the barrel also.and how far will I have to jack up the back to stop the oil from flowing out? (IMG:style_emoticons/default/welcome.png) Go to the member vendors section & look up McMark (Origninal Customs) & contact him about getting his modification for double o-rings for the angle drive. I'm sure he can work out something for you to use/trade/core your parts for it. He machines a 2nd groove for the 2nd o-ring, to eliminate this common 914 trans leak problem. No affiliation, just a tip! (IMG:style_emoticons/default/biggrin.gif) PS - You'll have the entire transaxle drain with the removal of the angle drive & have to refill it with new gear oil - no way around it, but a good idea to change the gear oil occasionally any-hoo! |
Lo-Fi Version | Time is now: 6th June 2024 - 12:33 PM |
