2.4T engine, Change engine in a 914 |
Niklas |
Aug 13 2010, 08:23 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
Is a 911 engine 2.4 T a good engine to use in a 914 ? What do I have to change to use it ? The engine is complete from the 911 with all the parts. My car is a -72 1.7. Greetings from Sweden on the lefthanders day. Niklas |
proto31 |
Aug 13 2010, 11:26 AM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
I agree with Andy, I had an original 6 with a 2.0 and it was a blast to drive, 130 HP is nearly double what you currently have, plus the added torque. If you're looking for raw power than you need to look for a 3.2 or 3.6. Building a 2056 will cost more than rebuilding the 2.4 (assuming it even needs a rebuild) even to "E" (add $500 for E pistons and $300 for cam regrind). Just my $.02.
Dan |
brant |
Aug 13 2010, 12:13 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with Andy, I had an original 6 with a 2.0 and it was a blast to drive, 130 HP is nearly double what you currently have, plus the added torque. If you're looking for raw power than you need to look for a 3.2 or 3.6. Building a 2056 will cost more than rebuilding the 2.4 (assuming it even needs a rebuild) even to "E" (add $500 for E pistons and $300 for cam regrind). Just my $.02. Dan Dan, I disagree on the comment about building a 2056 costing more if you take a -6 to a higher spec, you probably need to replace the cylinders too. And a set of pistons new is going to be over 1K, not 500. Plus a true E or S spec is going to need port work, heads (installing bigger valve seats is about a $1200 job and makes finding better heads the preferred choice), not to mention the case limitations of an early case (early aluminum cases are going for $2000 these days). Rebuilding more parts on a motor with more cylinders, usually costs more than a motor with less cylinders the -6 is going to cost more to rebuild in my book and I think that an important part of the answer for the original poster to know is that converting a -4 chassis to use a -6 motor is expensive. (where as the 2056 does not have the conversion costs associated with the chassis) granted the -6 will be an awesome car but it won't be "cheaper" you can factor a rebuild a 100 different ways, but here is my rough way: 914/4 starting chassis +with rebuilt 2056 + front cooler= $8K 914/4 starting chassis +rebuilt 2.4S spec motor + front cooler likely at over 150hp + full -6 conversion bits = $14K finding a used -4 motor would be apples to apples. Most people would put the cost of converting the chassis somewhere around 5K. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:00 AM |
