Upside of a scissor lift |
scotty b |
Aug 10 2010, 07:13 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Makes unfolding a 914 a lot easier (IMG:style_emoticons/default/smile.gif) The nature of the scissor lift puts all of the support back into the car once it is off the ground. Note in the pics the original door gap, and how the door has begun to droop, and once I ran the lift up, the gap opened back up and the door raised back into it's proper position. Measure everything and install bracing while in the air, dropped it down and all stayed in place (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
charliew |
Aug 13 2010, 06:44 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I think it needs a little more, the stripes and the handle pocket looks a little low still but you can fix it with the brace. The lift does give a lot of help though. Maybe a poboy could use a long 4x4 on each side with a floor jack under each side and one at the front in the center to get the same results.
Lo-Fi Version | Time is now: 3rd June 2024 - 12:29 AM |
