| VaccaRabite |
Aug 16 2010, 10:38 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,952 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
A few years ago, I saw someone make an air filter housing for a dual carbed /4 that was similar to the old air filter housings for a /6. you know, this style:
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1281985157.1.jpg) In my continuing effort to quiet down my ride, I need to reduce the sound of my intake. Also, this would allow me to use a proper paper filter rather then the kinda craptastic K&N filters - which seem to be the only game in town if you are using dual carbs. Anyone? Zach |
| VaccaRabite |
Aug 16 2010, 08:07 PM
Here is my idea.
I'll take a modern airbox that used a regular rectangular air filter. it will be mounted tot he firewall. a 4 inch tube will go to the pass side wheel well, drawing cool air from there. two 3 inch holes on the filtered side. Flex hose will link them to some carb tops with three inch inlets. Since all the filtration is done in the air box, the only purpose of the carb hats will be to feed cool clean air into the carbs. I figure I can use my existing bases and tops. Where the filters go could be layed up in fiberglass. With this configuration I should not impact any of the other function in my engine bay. The flex tube will give me vibration and movement since the engine will be floating on the mounts, and the air box won't. This should give me plenty of air to breathe and really quiet down my carbs. Right? Let me know if anyone sees a flaw in this. Zach |
| ldsgeek |
Aug 17 2010, 11:59 AM
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Here is my idea. I'll take a modern airbox that used a regular rectangular air filter. it will be mounted tot he firewall. a 4 inch tube will go to the pass side wheel well, drawing cool air from there. two 3 inch holes on the filtered side. Flex hose will link them to some carb tops with three inch inlets. Since all the filtration is done in the air box, the only purpose of the carb hats will be to feed cool clean air into the carbs. I figure I can use my existing bases and tops. Where the filters go could be layed up in fiberglass. With this configuration I should not impact any of the other function in my engine bay. The flex tube will give me vibration and movement since the engine will be floating on the mounts, and the air box won't. This should give me plenty of air to breathe and really quiet down my carbs. Right? Let me know if anyone sees a flaw in this. Zach Be very careful taking air from the wheel well. A puddle (or even very wet road) can throw enough water to cause issues. Some of the rice cars use a water diverter of some type as they often take cold air from a wheel well or near the bumper, you might look for that part as well. LDS Geek |
| narino |
Aug 17 2010, 12:09 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
Looks like those Air boxes are 8 inches tall. I'm away from the car otherwise I'd go and measure it to see if it'd fit. Here is the cut-sheet for reference.
Attached thumbnail(s) |
Vacca Rabite Dual carb air filter housing Aug 16 2010, 10:38 AM
pcar916 I'm not getting but about 1/2 in of that image... Aug 16 2010, 11:01 AM
markb
I'm not getting but about 1/2 in of that imag... Aug 16 2010, 11:04 AM
I'm not getting but about 1/2 in of that imag... Aug 16 2010, 11:13 AM
Vacca Rabite Wierd. the image is hosted over on Pelican. Here... Aug 16 2010, 11:20 AM
Cevan
Wierd. the image is hosted over on Pelican. Her... Aug 16 2010, 11:24 AM
SirAndy Wierd. the image is hosted over on Pelican.
Fixed... Aug 16 2010, 01:00 PM
Vacca Rabite Somehting like this:
http://www.914world.com/bbs2/... Aug 16 2010, 11:39 AM
narino Zach - where did you find this setup?
http://www... Aug 17 2010, 02:33 PM
Vacca Rabite
http://ww... Aug 17 2010, 03:38 PM
dlee6204 For smaller single stack carbs... (This car was o... Aug 16 2010, 11:59 AM
Drums66
For smaller single stack carbs... (This car was ... Aug 16 2010, 01:13 PM
Vacca Rabite Huh. I wonder if I could use these (7617 and 7618... Aug 16 2010, 12:41 PM
veltror There are a number of GErman suppliers that do thi... Aug 16 2010, 01:15 PM
jmill Those are meant for turbo'd webers. I've ... Aug 16 2010, 01:16 PM
veltror http://www.udobeckertuning.de/picsparts/lufi.jpg Aug 16 2010, 01:22 PM
veltror The red one pictured is from Klaus tuning pretty g... Aug 16 2010, 01:37 PM
SirAndy this is what i would do if I went Carbs...
:idea:... Aug 16 2010, 01:42 PM
tomeric914
[quote name='veltror' post='1357059' date='Aug 16... Aug 16 2010, 02:01 PM
Drums66
:idea... Aug 17 2010, 03:44 PM
veltror The GWD system is is either 646 euro or 780 Euro..... Aug 16 2010, 02:31 PM
Root_Werks Zach, I went through all of this a while back, res... Aug 16 2010, 02:39 PM
Vacca Rabite
If you want, I have the early 912 aircleaner hous... Aug 16 2010, 08:29 PM
Root_Werks
If you want, I have the early 912 aircleaner hou... Aug 16 2010, 10:02 PM
SirAndy Let me know if anyone sees a flaw in this.
The two... Aug 16 2010, 08:19 PM
9146986 I'd think that to optimize it you'd want t... Aug 16 2010, 08:22 PM
bam914 You could use these. Might not fit do to the heig... Aug 17 2010, 06:23 AM
Vacca Rabite
You could use these. Might not fit do to the hei... Aug 17 2010, 06:34 AM
bam914 No. I just saw them when I was looking at doing s... Aug 17 2010, 06:51 AM
tomeric914 These have 3" inlets but require the CB filte... Aug 17 2010, 11:41 AM
Zundfolge I wonder if one could simply modify the 911 one to... Aug 17 2010, 11:49 AM
Root_Werks
I wonder if one could simply modify the 911 one t... Aug 17 2010, 12:20 PM
Root_Werks Check out this link:
http://cgi.ebay.com/ebaymoto... Aug 17 2010, 04:43 PM
narino
... after some planning, found you don't need... Aug 17 2010, 04:53 PM
Root_Werks
... after some planning, found you don't nee... Aug 18 2010, 08:29 AM
Vacca Rabite
Zach,
I'll box up everything I have for you.... Aug 17 2010, 05:14 PM
Vacca Rabite Indeed. I want to be able to drive my son around ... Aug 18 2010, 08:50 AM
Vacca Rabite Dan, I got your package today! :trophy:
Well,... Aug 22 2010, 01:01 PM
Root_Werks
Well... Sep 9 2010, 09:26 AM
FourBlades I am also interested in quieting my car a little m... Aug 22 2010, 02:15 PM
campbellcj
I am also interested in quieting my car a little ... Sep 10 2010, 10:02 PM
Vacca Rabite Depending on how your car is set up, a lot of it i... Aug 22 2010, 02:23 PM
FourBlades I have a regular engine grill. I like the GT styl... Aug 22 2010, 05:47 PM
Vacca Rabite There was a lot in that box!
the 356 air clea... Sep 9 2010, 04:36 PM
Root_Werks I think they are actually 912 early for just a cou... Sep 10 2010, 10:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 02:43 PM |
