| bgravolet |
Aug 21 2010, 10:26 PM
Newbie ![]() Group: Members Posts: 5 Joined: 3-October 06 From: New Orleans Member No.: 6,983 |
Hello all, can you please help. I don't want to cut an access hole or drop the engine... But can you tell me how to access the pulley and remove the nut to change the fan belt? I've tried everything and would need four triple jointed arms it seems.
Also, how do you find TDC easily so I can adjust the valves? Thank you in advance. Ben |
| ClayPerrine |
Aug 21 2010, 10:47 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
First.. the timing marks. On a factory six flywheel there are timing marks already on it. If you don't have a factory flywheel, mark it the next time the engine is out. I did that, including the FE mark for the MFI.
Second, do you have the fan tool? If you do, then lay a blanket on the rear deck lid (or take the deck lid off completely), and lay down. Now you can reach around both sides of the fan housing to change the belt. You have to stack the shims by feel, but it can be done. |
| bgravolet |
Aug 21 2010, 11:12 PM
Thank you so much. Would I remove the starter to see the timing marks? And how do you recommend turning the engine to get the marks to show?
Sorry for all the newbie questions... It's my first experience with the flat 6. First.. the timing marks. On a factory six flywheel there are timing marks already on it. If you don't have a factory flywheel, mark it the next time the engine is out. I did that, including the FE mark for the MFI. Second, do you have the fan tool? If you do, then lay a blanket on the rear deck lid (or take the deck lid off completely), and lay down. Now you can reach around both sides of the fan housing to change the belt. You have to stack the shims by feel, but it can be done. |
bgravolet 914-6 tech help needed Aug 21 2010, 10:26 PM
SLITS First, is it a conversion or a "real" si... Aug 22 2010, 07:13 AM
eitnurg Everyone will have their own method for the fanbel... Aug 22 2010, 08:21 AM
GeorgeRud There's an easy 3 step procedure to change the... Aug 22 2010, 08:23 AM
pcar916 The hardest thing is to get the correct number of ... Aug 22 2010, 09:23 AM
Jeffs9146 The factory 6 has a view spot where you can see th... Aug 22 2010, 10:08 AM
bgravolet Thank you all for the advice. I hate to cut the ca... Aug 22 2010, 10:11 AM
ClayPerrine Just one word of advise...
Never turn a six backw... Aug 22 2010, 04:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 08:34 AM |
