avidfanjpl |
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region ![]() |
I really only want to drop the trans to do a complete overhaul. The leaks got to me today, and then I think I sheared something. No noise, just no forward motion, and that is OK, because I have a new clutch plate and need a new clutch cable as the existing one is a skinny one and all stretched out.
I know I have to drop the CV's and rebuild them, so I will start there when I get the tool bit tomorrow. I know also to drop the reverse switch, the ground, and I have a new strap, and the starter, clutch cable and all the bolts holding on the tranny, then the rear mounts, which I may replace, but is that about it? It pisses me off to no end that I have to probably drop the SSHE's, which I just frigging put on. I am replacing the muffler, and wonder if I can leave the SSHE's in place? Too risky? It was a total PITA to get the SSHE's on and perfect. Just last weekend, but like I said, time to pull the transmission. The leaks will go away. Soon, I hope, then I have to get Dr. Evil's video, the tool, and McMark's gasketed speedo wonder. Hayne's is just too vague, and yes, I know I need the video, then the parts figured out. I looked for a thread, and could not find one from A to Z. Anyone know of one here? I am about to become a transmission dilettante. Anything else before I drain the brand new gear oil? Thanks! |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
I did it once and it was a PITA. Particularly getting it back in. If you have a transmission jack or a couple of guys with strong arms it would be easy enough but working alone I think it easier to drop the whole drive train.
If you do it don't forget to support the engine. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:39 PM |
