| bgravolet |
Aug 21 2010, 10:26 PM
Newbie ![]() Group: Members Posts: 5 Joined: 3-October 06 From: New Orleans Member No.: 6,983 |
Hello all, can you please help. I don't want to cut an access hole or drop the engine... But can you tell me how to access the pulley and remove the nut to change the fan belt? I've tried everything and would need four triple jointed arms it seems.
Also, how do you find TDC easily so I can adjust the valves? Thank you in advance. Ben |
| pcar916 |
Aug 22 2010, 09:23 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
The hardest thing is to get the correct number of shims under the fan pulley while it's in the car. Beast of a job that is. Beer only after it's finished.
bgravolet 914-6 tech help needed Aug 21 2010, 10:26 PM
ClayPerrine First.. the timing marks. On a factory six flywhe... Aug 21 2010, 10:47 PM
bgravolet Thank you so much. Would I remove the starter to s... Aug 21 2010, 11:12 PM
SLITS First, is it a conversion or a "real" si... Aug 22 2010, 07:13 AM
eitnurg Everyone will have their own method for the fanbel... Aug 22 2010, 08:21 AM
GeorgeRud There's an easy 3 step procedure to change the... Aug 22 2010, 08:23 AM
Jeffs9146 The factory 6 has a view spot where you can see th... Aug 22 2010, 10:08 AM
bgravolet Thank you all for the advice. I hate to cut the ca... Aug 22 2010, 10:11 AM
ClayPerrine Just one word of advise...
Never turn a six backw... Aug 22 2010, 04:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 08:34 AM |
