> Distributor help, a noobie question
weird_looking_cactus
post Mar 17 2004, 05:14 PM
Cactus
Well I had my car running pretty good on 2 pistions it would idle good and when I pressed on the gas it go up just slow. Then I decied to fix the other 2 pistions now its running on all four (IMG:style_emoticons/default/smile.gif). But I really mess around with the distrubutor by turning the whole thing and the distrubutor moves really easy now and I can't seem to get it into that sweet spot again so it will stay at a idle. I can get it to start up but then it just dies or will stay at a idle super low idle for about 10 seconds. So how do I make the distributor tight and how do I find the right spot for it to stay running. Thanks
lapuwali
post Mar 17 2004, 05:32 PM
Not another one!
First, it's a matter of about 10 crank degrees for the idle sweet spot, which is only 5 distributor degrees. Very little distributor rotation is required to move it out of that range. As for getting it spot on, you need to get a timing light and start using the marks on the fan. The full procedure is detailed in a number of places, including the Pelican Parts tech articles. If you're still running points, you also need to set the points gap (aka setting dwell), and make sure the points are in good shape.
- Lo-Fi Version Time is now: 4th July 2025 - 01:04 AM
