| william1764 |
Aug 23 2010, 08:37 AM
Member ![]() ![]() Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
I'm considering replacing the Triad exhaust system which came with the car. What is considered the best all around system by most? My preference is a single tip product (IMG:style_emoticons/default/confused24.gif)
| william1764 |
Aug 23 2010, 08:52 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad?
I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? |
| realred914 |
Aug 23 2010, 09:35 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler |
| william1764 |
Aug 23 2010, 10:02 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler The probem was there before the carb work. MUCH less of an issue now but still pops reguarly on decel which drives me nuts. I was told the Triad could be the problem but it was from someone who is not a Triad fan so other opinions would be useful. |
| realred914 |
Aug 23 2010, 10:10 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler The probem was there before the carb work. MUCH less of an issue now but still pops reguarly on decel which drives me nuts. I was told the Triad could be the problem but it was from someone who is not a Triad fan so other opinions would be useful. exhaust leaks can be a source of decel poping also. make sure that is checked out |
william1764 Exhaust recommendations for 914 - 2.0 Aug 23 2010, 08:37 AM
vsg914 Bursch gives good preformance and not near as loud... Aug 23 2010, 08:39 AM
dr914@autoatlanta.com
Bursch gives good preformance and not near as lou... Aug 23 2010, 08:40 AM
vsg914 Hmm, tough Q. maybe a 4 or 5? Aug 23 2010, 09:31 AM
Bristol Another vote for the Bursch exhaust. I've got... Aug 23 2010, 10:12 AM
william1764
Another vote for the Bursch exhaust. I've go... Aug 23 2010, 10:52 AM
Bleyseng I really don't think its the Triad exhaust, bu... Aug 23 2010, 10:28 AM
william1764
I really don't think its the Triad exhaust, b... Aug 23 2010, 10:50 AM
Tom I've had a triad on for several years, never h... Aug 23 2010, 12:10 PM
william1764
I've had a triad on for several years, never ... Aug 23 2010, 12:27 PM
Philip W.
I'm considering replacing the Triad exhaust s... Aug 23 2010, 12:34 PM
william1764
I'm considering replacing the Triad exhaust ... Aug 23 2010, 02:07 PM
JmuRiz I haven't had issue with my triad...when my ca... Aug 23 2010, 03:32 PM
Gint The Triad itself isn't the cause of your poppi... Aug 23 2010, 04:47 PM
william1764 Thanks all. I guess I need to further check for ex... Aug 23 2010, 06:26 PM
ripper911 What do Y'all think about the tangerine racing... Aug 23 2010, 06:37 PM
9146986 I like the stock muffler. Doesn't have the ra... Aug 23 2010, 08:20 PM
DanT or you could...... Aug 23 2010, 09:03 PM
william1764
or you could......
That is cool looking - who m... Aug 24 2010, 10:14 AM
DanT
or you could......
That is cool looking - who ... Aug 24 2010, 11:53 AM
william1764
[quote name='william1764' post='1360519' date='Au... Aug 24 2010, 11:57 AM
Als914 I love my Borla, S.S.= low, mellow note.
Aug 24 2010, 10:51 AM
Tom There was a thread on here a few months back about... Aug 24 2010, 11:51 AM
william1764
There was a thread on here a few months back abou... Aug 24 2010, 11:57 AM
GeorgeRud Though they're not inexpensive, the stock fact... Aug 24 2010, 05:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 04:40 AM |
