| orange914 |
Aug 20 2008, 11:29 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i am interested in the REAL world cost and issues incured by others who have built these motors. i recently finished one and so far am extreemly happy with how strong and smooth it runs. there where issues as with alot of things but after working thru them, all is well. my 2056 probably has a bit more done to it than most 2056 builds, that may account for the successful outcome BUT maybe not. from what i've seen this is a highly sucessful combination.
don't be shy and tell us what ALL was done and your detailed experiance with building/driving it. this could be a great help for past and present 2056 builds. if there is interest i'll make another poll on presures and temp.'s mike (IMG:style_emoticons/default/beerchug.gif) EDIT MCMARK: Added "No Problems" |
| JimN73 |
Aug 24 2010, 09:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
I'm going thru a 2056 rebuild right now, the outcome of a spun rod bearing. Looked like everything was original when I opened the case, so I decided to 'upgrade' to 96 mm pistons, more performance oriented cam, higher compression and lightened flywheel.
The original estimate was for about $2K in parts, including a slush fund for stuff I didn't know about and $1K for the machine shop to do an align bore if needed, clean up the crank, lighten the flywheel and surface the heads. The plan was to do some/most/all of the work myself. I was given an estimate of about 25 hours for the garage to do it. As noted above, the heads can really bite you in the butt. Mine had cracks in the exhaust ports. The options are to have them repaired ($400 to $800) and hope the repair is done right and will last, buy 1.8 liter heads from AA for $950 each or buy new from Jake Raby. I bought new at about $3,300. that's a lot, but it's not as bad as it seems. In addition to the heads, you get stainless valves, springs, shims, adjusters, intake, exhaust, and rocker studs, cam camgear and lifters - maybe I left something out. Doubled the cost of the project, though. |
orange914 CALLING ALL 2056 engine owner/builders Aug 20 2008, 11:29 PM
Jake Raby I'll enter this one as an Enthusiast, not a pr... Aug 20 2008, 11:52 PM
orange914
I did our spark plug strengthening procedures to... Aug 21 2008, 01:54 AM
McMark My first 2056 was built with a set of AA pistons a... Aug 21 2008, 02:32 AM
orange914
My first 2056 was built with a set of AA pistons ... Aug 21 2008, 06:49 PM
sww914 My first 2056 is still my first 2056. I spent unde... Aug 21 2008, 02:53 AM
McMark Steve, are you aware that there is a fore/aft adju... Aug 21 2008, 03:23 AM
sww914
Steve, are you aware that there is a fore/aft adj... Aug 21 2008, 09:29 PM
Vacca Rabite I built mine over the winter of 2007. my only iss... Aug 21 2008, 08:06 AM
Jake Raby Orange,
The heads you picked up off me were not po... Aug 21 2008, 08:48 AM
azbill My 2056 was expensive because I bought an engine f... Aug 21 2008, 09:41 AM
Aircooledfool
My 2056 was expensive because I bought an engine ... Apr 1 2012, 10:27 AM
Jake Raby Bill, thats one hell of a lot of torque from a sto... Aug 21 2008, 10:07 AM
396 Great reading... now how does one come up with a 2... Aug 21 2008, 10:42 AM
Matt Meyer
Great reading... now how does one come up with a ... Aug 21 2008, 11:44 AM
Jake Raby Follow the 1.7/ 1.8 >> 2.0 conversion articl... Aug 21 2008, 11:10 AM
396
Follow the 1.7/ 1.8 >> 2.0 conversion artic... Aug 21 2008, 01:59 PM
scottb my 2056 was expensive (>$7000) because i f... Aug 21 2008, 11:32 AM
pete-stevers i have never built one...but follow this engines t... Aug 21 2008, 11:49 AM
Joe Ricard I guess it all depends on what you want to spend o... Aug 21 2008, 11:51 AM
Al Meredith I built a 2056 about two years ago. It is in my 91... Aug 21 2008, 08:15 PM
McMark
IIRC, I got them for $500 when they were ava... Aug 21 2008, 09:07 PM
Vacca Rabite Hahaha! Someone necro-polled!
And I jus... Aug 22 2010, 06:26 PM
DanT mine was easy...
under $3K
no issues during b... Aug 22 2010, 07:36 PM
realred914
i am interested in the REAL world cost and issues... Aug 23 2010, 08:55 AM
orange914
[quote name='orange914' post='1069559' date='Aug ... Aug 23 2010, 06:46 PM
realred914
[quote name='orange914' post='1069559' date='Aug... Aug 24 2010, 09:32 AM
Bleyseng I can tell you mine..
Raby supplied 96mm J&E p... Aug 23 2010, 09:06 AM
realred914 Great thanks for the details!!!!... Aug 23 2010, 09:15 AM
Bleyseng The "Best" way is to reuse your 94mm cyl... Aug 23 2010, 09:24 AM
realred914
The "Best" way is to reuse your 94mm cy... Aug 23 2010, 09:28 AM
Vacca Rabite I have heard bad things about the AA sets for high... Aug 23 2010, 04:52 PM
Jake Raby Funny this popped back up.. I am assembling a 2056... Aug 23 2010, 06:10 PM
realred914
Funny this popped back up.. I am assembling a 205... Aug 24 2010, 09:39 AM
Jake Raby
[quote name='Jake Raby' post='1360279' date='Aug ... Aug 25 2010, 11:07 AM
Don M the crank has 260K on it now and still mic'd o... Aug 26 2010, 07:25 AM
Jake Raby
the crank has 260K on it now and still mic'd ... Aug 26 2010, 08:53 AM
Don M
The variance in the stock crank sizes is more tha... Aug 27 2010, 07:29 AM
Don M
The variance in the stock crank sizes is more th... Aug 30 2010, 08:16 PM
Jake Raby
[quote name='Don M' post='1361949' date='Aug 27 2... Aug 31 2010, 07:57 AM
Don M
A part number for a set of bearings isn't goi... Aug 31 2010, 06:48 PM
realred914
[quote name='Don M' post='1361437' date='Aug 26 2... Aug 27 2010, 09:21 AM
scotty b Jake, what are the limitations with stock 2.0 inje... Aug 25 2010, 09:13 AM
Cevan My cost was about $3000 total to rebuild a 2.... Aug 25 2010, 12:14 PM
realred914
My cost was about $3000 total to rebuild a 2... Aug 25 2010, 11:26 PM
Jake Raby
http://www.aircooledtechnology.com/store/home.php... Aug 26 2010, 01:04 AM
realred914
http://www.aircooledtechnology.com/store/home.ph... Aug 26 2010, 08:50 AM
Jake Raby Nope, no O/S or U/S bearings were used or availabl... Aug 31 2010, 07:06 PM
Don M
Nope, no O/S or U/S bearings were used or availab... Sep 1 2010, 09:07 PM
Jake Raby
Nope, no O/S or U/S bearings were used or availa... Sep 2 2010, 08:44 AM
realred914
[quote name='Don M' post='1364840' date='Sep 1 20... Sep 2 2010, 09:48 AM
Don M I finished the big end of the rods to the size nec... Sep 2 2010, 09:52 PM
realred914 still tyring to get the answer Jake: are you usin... Sep 2 2010, 08:06 AM
Bleyseng Ahh, its just some fancy Snake Oil...... Sep 2 2010, 09:10 AM
Jake Raby
Exactl... Sep 2 2010, 09:29 AM
Bleyseng I thought it was quite funny when I first saw it..... Sep 2 2010, 03:15 PM
pete-stevers Geoff...when are you guys coming back for a visit?... Sep 2 2010, 03:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 02:40 AM |
