> CALLING ALL 2056 engine owner/builders, survey for past AND future 2056 builders
survey for past 2056 builders
how much was final cost?
UNDER $2000 [ 9 ] ** [16.36%]
UNDER$3000 [ 16 ] ** [29.09%]
UNDER $4000 [ 8 ] ** [14.55%]
UNDER $5000 [ 10 ] ** [18.18%]
UNDER $6000 [ 7 ] ** [12.73%]
UNDER $7000 [ 2 ] ** [3.64%]
OVER $7000 [ 3 ] ** [5.45%]
what problem/issues did you have during build
BOTTOM END case/cam/crank/rods [ 3 ] ** [5.45%]
P&C'S [ 7 ] ** [12.73%]
HEADS [ 3 ] ** [5.45%]
FUEL/EXHAUST [ 0 ] ** [0.00%]
MORE THAN 1 AREA [ 5 ] ** [9.09%]
No problems [ 37 ] ** [67.27%]
what problem/issues did you have AFTER engine break in
BOTTOM END [ 2 ] ** [3.64%]
P&C'S [ 2 ] ** [3.64%]
HEADS [ 4 ] ** [7.27%]
FUEL/EXHAUST [ 8 ] ** [14.55%]
MORE THAN 1 AREA [ 2 ] ** [3.64%]
Total Votes: 165
Guests cannot vote
orange914
post Aug 20 2008, 11:29 PM
http://5starmediaworks.com/index.html
i am interested in the REAL world cost and issues incured by others who have built these motors. i recently finished one and so far am extreemly happy with how strong and smooth it runs. there where issues as with alot of things but after working thru them, all is well. my 2056 probably has a bit more done to it than most 2056 builds, that may account for the successful outcome BUT maybe not. from what i've seen this is a highly sucessful combination.
don't be shy and tell us what ALL was done and your detailed experiance with building/driving it. this could be a great help for past and present 2056 builds.
if there is interest i'll make another poll on presures and temp.'s
mike (IMG:style_emoticons/default/beerchug.gif)
EDIT MCMARK: Added "No Problems"
Jake Raby
post Aug 23 2010, 06:10 PM
Engine Surgeon
Funny this popped back up.. I am assembling a 2056 tonight, its the 160K mile engine that I tore down in this article on my site. I built this in 2002 for my personal 912E
http://www.aircooledtechnology.com/index.p...&Itemid=112
I am going back together with it almost exactly the same way, except with a new set of RS+ heads because the 2 liter castings were toast (as they ALWAYS are). I am actually going down on camshaft from a 9530 to a 9550 to better match the desires I have for the engine.
I plan on posting the build up with all the used parts and a few new ones on my site.. The 160K mile KB pistons are even being reused! My goal is to only make the same power the engine made previously, around 130HP at the flywheel, I'd like to see 110 RWHP but at a lower RPM than previously, this is for my 30K+ mile per year daily driver that needs to average north of 35 MPG..
This post has been edited by Jake Raby: Aug 23 2010, 06:11 PM
realred914
post Aug 24 2010, 09:39 AM
Group: Retired Members
QUOTE(Jake Raby @ Aug 23 2010, 05:10 PM) *
so I take it you really like the KB piston? Just wondering what advantages do you find over some of the others from a technical stand point? is the material or build qulaity, piston design (combustion chamber, pin hieght, etc...) that makes the KB your choice? I understand they are forged, which should be a good thing strength wise.
thanks for advice
Jake Raby
post Aug 25 2010, 11:07 AM
Engine Surgeon
QUOTE(realred914 @ Aug 24 2010, 08:39 AM) *
thanks for advice
My pistons were in such good shape at 160K that I ended up reusing them for the new build. I simply blasted them with corn cob media and cleaned them up well. These were THE FIRST 96mm KB pistons that the company made, they were the prototypes! After all that time they measured out perfectly and had no scuffing or wear, you'll see pics in my "rebuild" thread over on my forums when I put it all together after the engine is on the dyno.
The KB pistons are light, super strong and their composition makes them perfect for a hotter running aircooled engine, due to that we can run much tighter skirt clearances than with a JE, Mahle or etc.
As noted above, the heads can really bite you in the butt. Mine had cracks in the exhaust ports. The options are to have them repaired ($400 to $800) and hope the repair is done right and will last, buy 1.8 liter heads from AA for $950 each or buy new from Jake Raby.
My heads were used up.. Len refused to do any work on them and I respected that. I just picked up my set of RS+ heads from him yesterday for the new engine. Head castings have a service life, people learn that when they TRY to reuse the castings again only to spend a ton of money and still have 30+ year old heads that are on their last leg. I can rebuild these new RS+ heads for the next 30 years as they are at the beginning of their service life.
The only new parts I used in this engine was:
camshaft (changed the profile)
piston rings
cylinder head assemblies
main, rod and cam bearings
rods (swapped out a set to save time)
It'll go another 150K+, the crank has 260K on it now and still mic'd out to 2.1682 which is better than stock sizing with only a .0002 ovality between all 4 journals!
Wait till you see the transformation I have given this baby with minimum expenditure. I have all new stuff 20 feet away, but I'd rather prove how robust the parts are for another 150K!
Don M
post Aug 26 2010, 07:25 AM
is this right? seems to be o/s +.003
orange914   CALLING ALL 2056 engine owner/builders   Aug 20 2008, 11:29 PM
Jake Raby   I'll enter this one as an Enthusiast, not a pr...   Aug 20 2008, 11:52 PM
orange914   I did our spark plug strengthening procedures to...   Aug 21 2008, 01:54 AM
McMark   My first 2056 was built with a set of AA pistons a...   Aug 21 2008, 02:32 AM
orange914   My first 2056 was built with a set of AA pistons ...   Aug 21 2008, 06:49 PM
sww914   My first 2056 is still my first 2056. I spent unde...   Aug 21 2008, 02:53 AM
McMark   Steve, are you aware that there is a fore/aft adju...   Aug 21 2008, 03:23 AM
sww914   Steve, are you aware that there is a fore/aft adj...   Aug 21 2008, 09:29 PM
Vacca Rabite   I built mine over the winter of 2007. my only iss...   Aug 21 2008, 08:06 AM
Jake Raby   Orange, The heads you picked up off me were not po...   Aug 21 2008, 08:48 AM
azbill   My 2056 was expensive because I bought an engine f...   Aug 21 2008, 09:41 AM
Aircooledfool   My 2056 was expensive because I bought an engine ...   Apr 1 2012, 10:27 AM
Jake Raby   Bill, thats one hell of a lot of torque from a sto...   Aug 21 2008, 10:07 AM
396   Great reading... now how does one come up with a 2...   Aug 21 2008, 10:42 AM
Matt Meyer   Great reading... now how does one come up with a ...   Aug 21 2008, 11:44 AM
Jake Raby   Follow the 1.7/ 1.8 >> 2.0 conversion articl...   Aug 21 2008, 11:10 AM
396   Follow the 1.7/ 1.8 >> 2.0 conversion artic...   Aug 21 2008, 01:59 PM
scottb   my 2056 was expensive (>$7000) because i f...   Aug 21 2008, 11:32 AM
pete-stevers   i have never built one...but follow this engines t...   Aug 21 2008, 11:49 AM
Joe Ricard   I guess it all depends on what you want to spend o...   Aug 21 2008, 11:51 AM
Al Meredith   I built a 2056 about two years ago. It is in my 91...   Aug 21 2008, 08:15 PM
McMark   IIRC, I got them for $500 when they were ava...   Aug 21 2008, 09:07 PM
Vacca Rabite   Hahaha! Someone necro-polled! And I jus...   Aug 22 2010, 06:26 PM
DanT   mine was easy... under $3K no issues during b...   Aug 22 2010, 07:36 PM
realred914   i am interested in the REAL world cost and issues...   Aug 23 2010, 08:55 AM
orange914   [quote name='orange914' post='1069559' date='Aug ...   Aug 23 2010, 06:46 PM
realred914   [quote name='orange914' post='1069559' date='Aug...   Aug 24 2010, 09:32 AM
Bleyseng   I can tell you mine.. Raby supplied 96mm J&E p...   Aug 23 2010, 09:06 AM
realred914   Great thanks for the details!!!!...   Aug 23 2010, 09:15 AM
Bleyseng   The "Best" way is to reuse your 94mm cyl...   Aug 23 2010, 09:24 AM
realred914   The "Best" way is to reuse your 94mm cy...   Aug 23 2010, 09:28 AM
Vacca Rabite   I have heard bad things about the AA sets for high...   Aug 23 2010, 04:52 PM
Jake Raby   Funny this popped back up.. I am assembling a 2056...   Aug 23 2010, 06:10 PM
realred914   Funny this popped back up.. I am assembling a 205...   Aug 24 2010, 09:39 AM
Jake Raby   [quote name='Jake Raby' post='1360279' date='Aug ...   Aug 25 2010, 11:07 AM
Don M   the crank has 260K on it now and still mic'd o...   Aug 26 2010, 07:25 AM
Jake Raby   the crank has 260K on it now and still mic'd ...   Aug 26 2010, 08:53 AM
Don M   The variance in the stock crank sizes is more tha...   Aug 27 2010, 07:29 AM
Don M   The variance in the stock crank sizes is more th...   Aug 30 2010, 08:16 PM
Jake Raby   [quote name='Don M' post='1361949' date='Aug 27 2...   Aug 31 2010, 07:57 AM
Don M   A part number for a set of bearings isn't goi...   Aug 31 2010, 06:48 PM
realred914   [quote name='Don M' post='1361437' date='Aug 26 2...   Aug 27 2010, 09:21 AM
JimN73   I'm going thru a 2056 rebuild right now, the o...   Aug 24 2010, 09:56 AM
scotty b   Jake, what are the limitations with stock 2.0 inje...   Aug 25 2010, 09:13 AM
Cevan   My cost was about $3000 total to rebuild a 2....   Aug 25 2010, 12:14 PM
realred914   My cost was about $3000 total to rebuild a 2...   Aug 25 2010, 11:26 PM
Jake Raby   http://www.aircooledtechnology.com/store/home.php...   Aug 26 2010, 01:04 AM
realred914   http://www.aircooledtechnology.com/store/home.ph...   Aug 26 2010, 08:50 AM
Jake Raby   Nope, no O/S or U/S bearings were used or availabl...   Aug 31 2010, 07:06 PM
Don M   Nope, no O/S or U/S bearings were used or availab...   Sep 1 2010, 09:07 PM
Jake Raby   Nope, no O/S or U/S bearings were used or availa...   Sep 2 2010, 08:44 AM
realred914   [quote name='Don M' post='1364840' date='Sep 1 20...   Sep 2 2010, 09:48 AM
Don M   I finished the big end of the rods to the size nec...   Sep 2 2010, 09:52 PM
realred914   still tyring to get the answer Jake: are you usin...   Sep 2 2010, 08:06 AM
Bleyseng   Ahh, its just some fancy Snake Oil......   Sep 2 2010, 09:10 AM
Jake Raby   Ahh, its just some fancy Snake Oil...... Exactl...   Sep 2 2010, 09:29 AM
Bleyseng   I thought it was quite funny when I first saw it.....   Sep 2 2010, 03:15 PM
pete-stevers   Geoff...when are you guys coming back for a visit?...   Sep 2 2010, 03:47 PM
- Lo-Fi Version Time is now: 15th June 2026 - 03:18 AM
