> oil cooler adaptors, 3/8 vs. 1/2 inch sandwhich style
realred914
post Aug 24 2010, 02:54 PM
Group: Retired Members
looking for a good sandwhich adaptor to add an oil cooler. want one with a thermostat built in, I see several brands for sale, there are some big price differances too.
at any rate there are some ones that have 3/8 inch NPT inlet/outlet threads, and others that have 1/2 inch NPT threads inlet and outlet. the price differenace is considerable (nearly 3X)
seeing as the oil passages upto the filter are not all that fat anyway I figure, how much benifit would one get out of a 3/8 NPT fitting verses the 1/2 NPT? I still plan to use AN10 hose and fittings and have 1/2 inch NPT on the oil cooler itself, so the biggest restriction in the new system would be the 3/8 NPT fittings on the sandwhich adaptor. will this be a significant flow restriction or not verses the larger adaptor? the engine will be a daily driver motor, not a high rpm race motor.
McMark
post Aug 26 2010, 09:34 AM
914 Freak!
The thermostat isn't just about 'freezing weather'. You want the oil to come up to ideal temperature as quickly as possible. If you have a cooler without a thermostat, it takes longer for this to happen. You could skip the thermostat if you leave any fans turned off, and you don't move the car until optimum oil temp is reached.
realred914   oil cooler adaptors   Aug 24 2010, 02:54 PM
Mark Henry   I take that this is for a /4? Why do you need a b...   Aug 24 2010, 03:16 PM
realred914   I take that this is for a /4? Why do you need a ...   Aug 24 2010, 03:22 PM
underthetire   Try to find a adapter out of a for police intercep...   Aug 24 2010, 03:20 PM
realred914   any one have experiences with Derale or Hayden san...   Aug 25 2010, 07:50 AM
kg6dxn   I'm running a Transdapt remote filter on my V8...   Aug 25 2010, 04:44 PM
McMark   I've installed a few. All of them looked pret...   Aug 25 2010, 05:25 PM
realred914   I've installed a few. All of them looked pre...   Aug 25 2010, 11:18 PM
brant   McMark you use a thermostat???? I was under the ...   Aug 26 2010, 08:42 AM
DanT   I had a mocal sandwich adapter on my racecar....wi...   Aug 25 2010, 11:29 PM
realred914   I had a mocal sandwich adapter on my racecar....w...   Aug 25 2010, 11:56 PM
tradisrad   realred, don't foget this thread: http://www.9...   Aug 26 2010, 07:25 AM
DanT   plates and rows are two different things :)   Aug 26 2010, 08:37 AM
realred914   plates and rows are two different things :) r...   Aug 26 2010, 09:13 AM
McMark   The thermostat isn't just about 'freezing ...   Aug 26 2010, 09:34 AM
tradisrad   the mocal thermostat that I am using always allows...   Aug 26 2010, 09:43 AM
charliew   I was always under the impression that any oil lin...   Aug 26 2010, 03:01 PM
pcar916   I was always under the impression that any oil li...   Aug 26 2010, 05:23 PM
carr914   McMark you use a thermostat???? I was under the...   Aug 26 2010, 05:20 PM
- Lo-Fi Version Time is now: 22nd August 2025 - 05:32 AM
