Ground Light Out and No Charge - HELP |
vesnyder |
Aug 26 2010, 07:05 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I did a search and could not find anything, but where should I start - I noticed when I started my 914 last that the "charge" light on the dash was not lit. After I started the car I also noted that my Voltmeter, which usually shows 14+ volts is showing 12, and lesss when I load up the charging system with lights and fog lamps. What are the typical culprits?
ldsgeek |
Aug 27 2010, 09:59 AM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
I still hate the German style fuses from when I had a BMW 320i. Occasionally I would have to twist the fuses and r&r the relays so the car would start. When I get my 914 (i pick it up Sept 4 (IMG:style_emoticons/default/smile.gif) ) I am thinking of installing the modular replacement fuse panel I have seen just to avoid this problem from the start.
underthetire |
Aug 27 2010, 12:35 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I still hate the German style fuses from when I had a BMW 320i. Occasionally I would have to twist the fuses and r&r the relays so the car would start. When I get my 914 (i pick it up Sept 4 (IMG:style_emoticons/default/smile.gif) ) I am thinking of installing the modular replacement fuse panel I have seen just to avoid this problem from the start. You'll still have to deal with them on the relay board. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:53 PM |
