installing accessory guages |
TomR |
Aug 29 2010, 11:25 AM
Newbie Group: Members Posts: 27 Joined: 29-August 10 From: delaware Member No.: 12,117 Region Association: None |
Hi I have a '73 914 that is having an engine upgrade. I am looking to add an oil temp, oil pressure & cylinder head temp guages to car. Was thinking of putting them where climate controls are on dash. Won't need the climate controls as car will be fair weather driver only, & all heat exchangers are being removed from exhaust. Are there any kits out there to do this? Or has anybody tried this before? Any help would be great!
BarberDave |
Aug 30 2010, 05:38 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Are you aware the factory included the back half of the console wire harnes in every 73. It can be found under the carpet between the seats. just plug a stock console wireing harness in. You will have to run your own wireing for your CHT. As to putting the gauges in the dash. I think that would look fubard . My 2 cents. also you will need a Taco plate and the correct sender for your temp gauge. There are 3 gauge under dash panels sold every where. If you use stock size gauges that may be a problem finding a panel to fit. Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:09 AM |
