L-jet for 2056 |
L-jet for 2056 |
TargaToy |
Aug 29 2010, 07:55 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I had another topic going regarding my plan to build a 2056 from a spare 1.8 motor. Initially, I wanted to find out what was necessary to make my existing D-jet on my running 1.7 work with the future motor.
I learned that I need quite a few 2.0 D-jet components to make it work...and then from what I understand in reading Jake Raby's data on the 2056, I'll still max out at around 115 hp with the FI. So if I were to revitalize the L-jet system from my spare car instead (a 1975 1.8), would it be possible to get the 120-125 hp a carb'd 2056 makes? What tweaks exactly will be required to make the L-jet perform safely, and correctly? I have read that the fuel pressure may need to be raised. What are the other considerations and can they be handled by a competent DYI-er? |
Bleyseng |
Aug 30 2010, 02:47 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Run the LJet but you will have to adjust the AFM after its all up and running if you build a 2056 with a Raby cam. The stock setting will be too lean!
HP you will max out at 115hp with the 9550 or 120 with his newer cam, forget using the carb cams as the Ljet won't like em. 115hp is plenty with smooth power....the Ljet FP must be used and the dizzy is nice too. |
realred914 |
Aug 30 2010, 10:13 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Run the LJet but you will have to adjust the AFM after its all up and running if you build a 2056 with a Raby cam. The stock setting will be too lean! HP you will max out at 115hp with the 9550 or 120 with his newer cam, forget using the carb cams as the Ljet won't like em. 115hp is plenty with smooth power....the Ljet FP must be used and the dizzy is nice too. what is the new cam like listed above, compaired to teh 9550 cam? I am int eh market for a big 2 liter rebuild will be running 2 liter D-jet is the plan wnat a ncie street car with decent mpg and power. what are the trade offs between these two cams???? Jake, Bleyseng opinions on the two cams please???? |
Lo-Fi Version | Time is now: 11th June 2024 - 05:03 AM |
