| budk |
Aug 30 2010, 07:28 PM
Yes! It's a Bumblebee! ![]() ![]() ![]() Group: Members Posts: 685 Joined: 24-July 10 From: Jasper, TN Member No.: 11,970 Region Association: MidAtlantic Region |
I just brought home a 74 2.0 that was last run in 1995.
Supposedly it was running and had a fuel pump problem and it was parked and not touched since. I'm looking for suggestions as to where to start. I'd like to get a handle on the condition of the engine first so I'm looking for suggestions. Opinions are be appreciated. Pics (bad pics) are farther down in this thread. |
| Tom_T |
Aug 30 2010, 10:46 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
(IMG:style_emoticons/default/welcome.png) .... to all y'uns from a former PGHer! .... & still a Steeler & Bucs fan! (IMG:style_emoticons/default/biggrin.gif)
OK - a few premises here: Salted Roads = Rust Winter/Snow = Rust PGH Cloud Busters = Rust ALL 914s ANYWHERE = RUST!!!! Do a full assessment of the 914 - pull, poke & dig EVERYWHERE you can think of, and then where you can't think of! (IMG:style_emoticons/default/dry.gif) Pull Rockers & look at longs outside & pull carpets & seats & look at inner longs & floor pans inside & underneath; Pull steering rack as noted by Ron/slits & also check for rust on the underbody, especially at the steering rack/crossmember struts & other connection points; Pull the engine bay firewall pad & look for rust behind on firewall & engine shelf (also on inside of cabin behind pad; Check battery tray/support, rear longs/engine shelves/suspension consoles/etc. in the hell hole/battery tray area & under engine bay relay board; Pull of all F&R trunk lids' seals/gaskets & check for rust & also on both trunk floors, around taillights, at F & R bumper bolt connections, at rear tow-hook stud & F horn & foglight connections, inside headlight boxes & drain tubes; Pull cowl/fender joint seals & check crack for rust, as well as along cowl at windshield trim/frame, wiper shaft insets, washer jets, vent, etc.; Check door sills, jambs, along the sail-to-rear-fender area along the & under the sail vinyl & bright trim, & along sails' inside/outside & rollbar top/bottom; Pull outer door seals on the doors & check seal channel & along bottoms of doors, as well as top at windows & mirror(s); ... and then check some more, following the probable water routes from what you find above. My 914 was rustorated in 1980, driven in SoCal to 5/85 when some gal whacked it in a UCLA parking structure, then stored in my dry SoCal garage clean & non-rusty then, but came out with extensive "new" rust damage when I got back to assess it for repairs/resto! The sheet metal pre-76/77 were not galvanized nor other rust preventative treatment at the factory. FYI - all 914s were built in 75 or earlier, so are just as rust prone as any Porsche, VW, BMW, MBZ or any other car of that 50's-60's-70's era! (IMG:style_emoticons/default/dry.gif) Don't try to run the engine until you change out all of the soft lines (high pressure fuel & vacuum hoses), & ditto for the brake lines (calipers & MC may need rebuilds or replacement - MC's new still available, but upgrade to 19mm 914-6/911 ATE is less than 914/4 17mm - so go for the upgrade). Sounds like you'll need a fuel pump, but the OEM Bosch are NLA, so stick with a rebuilt by Bosch & not other companies' rebuilds of the Bosch FP. BTW - I can't see someone not driving the 914 because it needs a fuel pump - esp.since they were still available new back then for a fairly reasonable price (relatively speaking for Porsche parts). I'm guessing there was more wrong that they didn't want to do. Also now in the PGH area is "Dr. Evil" the 914 Tranny Wiz on here (transaxle rebuilding - not cross-dressing that is - although the last WCR pix gave us all some doubts! (IMG:style_emoticons/default/lol-2.gif) ). He's doing his residency there & lives out in/near Mt Washington IIRC. Find him in the member search & send him a PM. I'm sure he'd like to know another local Teener, & there are a couple of other PGH Teeners on here too (I'm out in SoCal since `63). Good Luck, then enjoy running the sucker all out in the Alleghenies!!!! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
budk 15 years in storage - Paint Code pic added Aug 30 2010, 07:28 PM
mepstein Ask your bank about a second mortgage.
Check the... Aug 30 2010, 07:42 PM
SirAndy what should I do first?
Post pictures here!
:... Aug 30 2010, 07:46 PM
tornik550 I think that I should chime in and say that the ca... Aug 30 2010, 08:05 PM
jt914-6 Clean out the mice nests/mess and check for wiring... Aug 30 2010, 08:54 PM
SLITS :agree:
Remove the rack access panel on the bott... Aug 30 2010, 09:08 PM
budk Thanks for all the good input.
It's certainly... Aug 31 2010, 03:46 AM
swl
I understand the concern that a fuel pump should... Aug 31 2010, 04:54 AM
Tom_T How to post pix here -
http://www.914world.com/bbs... Aug 31 2010, 03:50 AM
Bleyseng just post alot of pics so we can advise you :popco... Aug 31 2010, 03:51 AM
budk SWL - thanks - i am thinking along the same lines.... Aug 31 2010, 05:22 AM
swl Now you're talking Bud! Any guy who's... Aug 31 2010, 05:44 AM
914Sixer What is the VIN number? It looks like it maybe a ... Aug 31 2010, 06:27 AM
budk
What is the VIN number? It looks like it maybe a... Aug 31 2010, 06:34 AM
nsr-jamie penetrating fluid for a few days should help too i... Aug 31 2010, 06:39 AM
ME733 .......THE VERY FIRST THING to do is to rebuild th... Aug 31 2010, 07:12 AM
budk
.......THE VERY FIRST THING to do is to rebuild t... Aug 31 2010, 07:25 AM
Krieger To be fully confident I would consider going throu... Aug 31 2010, 07:50 AM
budk
To be fully confident I would consider going thro... Aug 31 2010, 07:55 AM
dlee6204 Before you do ANYTHING, you should sit in the driv... Aug 31 2010, 08:53 AM
markb
Before you do ANYTHING, you should sit in the dri... Aug 31 2010, 01:08 PM
tornik550 I am absolutely convinced that this is a bumblebee... Aug 31 2010, 09:02 AM
rick 918-S :wttc: :smash: :sawzall: :welder: Aug 31 2010, 09:10 AM
Bristol I would do what others have recommended on thoroug... Aug 31 2010, 09:32 AM
underthetire
I would do what others have recommended on thorou... Aug 31 2010, 04:30 PM
Tom_T All good advice above - don't run the motor un... Aug 31 2010, 10:36 AM
budk
All good advice above - don't run the motor u... Aug 31 2010, 11:10 AM
strawman
It's tough to live in the East and not have ... Aug 31 2010, 11:28 AM
SirAndy I plan on using por15 on any surface rust that I c... Aug 31 2010, 04:08 PM
Rav914 When I bought my '74, it had been 'stored... Aug 31 2010, 10:57 AM
Dr Evil Score, the guy who bought the car is a neighbor :t... Aug 31 2010, 12:27 PM
budk
Score, the guy who bought the car is a neighbor :... Aug 31 2010, 12:48 PM
Dr Evil 20 min away with a nice car to start with. There i... Aug 31 2010, 12:54 PM
budk
20 min away with a nice car to start with. There ... Aug 31 2010, 01:37 PM
Tom_T
20 min away with a nice car to start with. There ... Aug 31 2010, 07:00 PM
RFoulds I am doing the same thing. Mine was in storage 22... Aug 31 2010, 01:29 PM
Rod First thing you should do is pull up a deck chair,... Aug 31 2010, 04:33 PM
windforfun
First thing you should do is pull up a deck chair... Aug 31 2010, 05:40 PM
scotty b Do yourself a favor and spend the money to have th... Aug 31 2010, 05:51 PM
Ian Stott I have a 73 2.0 and it had been stored for quite s... Aug 31 2010, 06:48 PM
jsayre914 Hey Bud, I just noticed you work for the departmen... Aug 31 2010, 07:03 PM
budk
Hey Bud, I just noticed you work for the departme... Aug 31 2010, 08:20 PM
faux916 Good Score Bud! I will email you when I get so... Aug 31 2010, 07:25 PM
budk Dr. Evil is coming tonight so I should have a litt... Sep 2 2010, 08:03 AM
Tom_T
Dr. Evil is coming tonight so I should have a lit... Sep 2 2010, 02:33 PM
budk Lot's done to the car this past weekend. Gas... Sep 7 2010, 07:51 AM
siverson > I'm looking for suggestions as to where t... Sep 7 2010, 06:47 PM
budk
> I'm looking for suggestions as to where ... Sep 8 2010, 07:36 AM
type47 Send you engine cooling tin and intake runners and... Sep 8 2010, 01:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:49 AM |
