> 15 years in storage - Paint Code pic added
budk
post Aug 30 2010, 07:28 PM
Yes! It's a Bumblebee!
I just brought home a 74 2.0 that was last run in 1995.
Supposedly it was running and had a fuel pump problem and it was parked and not touched since.
I'm looking for suggestions as to where to start. I'd like to get a handle on the condition of the engine first so I'm looking for suggestions.
Opinions are be appreciated.
Pics (bad pics) are farther down in this thread.
Krieger
post Aug 31 2010, 07:50 AM
To be fully confident I would consider going through the entire brake system. New master, rebuild calipers, new hoses. Probably turn rotors if really rusty. Once you do brakes and fuel system your safe and will probably be done with the car and never have any problems... not. But seriously I'd get it running first to see what all it needs then maybe yank that engine. You can change all the fuel lines in the car with the engine in. Consider replacing the center tunnel lines with stainless lines. Member Chris Foley sells these in the vendor area. Check the condition of the cv boots too. Grease up the rear trunk hinge/rollers.
budk
post Aug 31 2010, 07:55 AM
QUOTE(Krieger @ Aug 31 2010, 09:50 AM) *
Great info about the brakes/lines. When I pushed the car on the trailer you could hear the brakes rubbing, but they worked well enough to stop the car when we pushed her into the garage. Also, in the trunk, there are 2 brand new rotors and a box that has an old master cylinder in it.. so, I assume that was replaced at some point in the past.
budk   15 years in storage - Paint Code pic added   Aug 30 2010, 07:28 PM
mepstein   Ask your bank about a second mortgage. Check the...   Aug 30 2010, 07:42 PM
SirAndy   what should I do first? Post pictures here! :...   Aug 30 2010, 07:46 PM
tornik550   I think that I should chime in and say that the ca...   Aug 30 2010, 08:05 PM
jt914-6   Clean out the mice nests/mess and check for wiring...   Aug 30 2010, 08:54 PM
SLITS   :agree: Remove the rack access panel on the bott...   Aug 30 2010, 09:08 PM
Tom_T   :wttc: .... to all y'uns from a former PGHer...   Aug 30 2010, 10:46 PM
budk   Thanks for all the good input. It's certainly...   Aug 31 2010, 03:46 AM
swl   I understand the concern that a fuel pump should...   Aug 31 2010, 04:54 AM
Tom_T   How to post pix here - http://www.914world.com/bbs...   Aug 31 2010, 03:50 AM
Bleyseng   just post alot of pics so we can advise you :popco...   Aug 31 2010, 03:51 AM
budk   SWL - thanks - i am thinking along the same lines....   Aug 31 2010, 05:22 AM
swl   Now you're talking Bud! Any guy who's...   Aug 31 2010, 05:44 AM
914Sixer   What is the VIN number? It looks like it maybe a ...   Aug 31 2010, 06:27 AM
budk   What is the VIN number? It looks like it maybe a...   Aug 31 2010, 06:34 AM
nsr-jamie   penetrating fluid for a few days should help too i...   Aug 31 2010, 06:39 AM
ME733   .......THE VERY FIRST THING to do is to rebuild th...   Aug 31 2010, 07:12 AM
budk   .......THE VERY FIRST THING to do is to rebuild t...   Aug 31 2010, 07:25 AM
Krieger   To be fully confident I would consider going throu...   Aug 31 2010, 07:50 AM
budk   To be fully confident I would consider going thro...   Aug 31 2010, 07:55 AM
dlee6204   Before you do ANYTHING, you should sit in the driv...   Aug 31 2010, 08:53 AM
markb   Before you do ANYTHING, you should sit in the dri...   Aug 31 2010, 01:08 PM
tornik550   I am absolutely convinced that this is a bumblebee...   Aug 31 2010, 09:02 AM
rick 918-S   :wttc: :smash: :sawzall: :welder:   Aug 31 2010, 09:10 AM
Bristol   I would do what others have recommended on thoroug...   Aug 31 2010, 09:32 AM
underthetire   I would do what others have recommended on thorou...   Aug 31 2010, 04:30 PM
Tom_T   All good advice above - don't run the motor un...   Aug 31 2010, 10:36 AM
budk   All good advice above - don't run the motor u...   Aug 31 2010, 11:10 AM
strawman   It's tough to live in the East and not have ...   Aug 31 2010, 11:28 AM
SirAndy   I plan on using por15 on any surface rust that I c...   Aug 31 2010, 04:08 PM
Rav914   When I bought my '74, it had been 'stored...   Aug 31 2010, 10:57 AM
Dr Evil   Score, the guy who bought the car is a neighbor :t...   Aug 31 2010, 12:27 PM
budk   Score, the guy who bought the car is a neighbor :...   Aug 31 2010, 12:48 PM
Dr Evil   20 min away with a nice car to start with. There i...   Aug 31 2010, 12:54 PM
budk   20 min away with a nice car to start with. There ...   Aug 31 2010, 01:37 PM
Tom_T   20 min away with a nice car to start with. There ...   Aug 31 2010, 07:00 PM
RFoulds   I am doing the same thing. Mine was in storage 22...   Aug 31 2010, 01:29 PM
Rod   First thing you should do is pull up a deck chair,...   Aug 31 2010, 04:33 PM
windforfun   First thing you should do is pull up a deck chair...   Aug 31 2010, 05:40 PM
scotty b   Do yourself a favor and spend the money to have th...   Aug 31 2010, 05:51 PM
Ian Stott   I have a 73 2.0 and it had been stored for quite s...   Aug 31 2010, 06:48 PM
jsayre914   Hey Bud, I just noticed you work for the departmen...   Aug 31 2010, 07:03 PM
budk   Hey Bud, I just noticed you work for the departme...   Aug 31 2010, 08:20 PM
faux916   Good Score Bud! I will email you when I get so...   Aug 31 2010, 07:25 PM
budk   Dr. Evil is coming tonight so I should have a litt...   Sep 2 2010, 08:03 AM
Tom_T   Dr. Evil is coming tonight so I should have a lit...   Sep 2 2010, 02:33 PM
budk   Lot's done to the car this past weekend. Gas...   Sep 7 2010, 07:51 AM
siverson   > I'm looking for suggestions as to where t...   Sep 7 2010, 06:47 PM
budk   > I'm looking for suggestions as to where ...   Sep 8 2010, 07:36 AM
type47   Send you engine cooling tin and intake runners and...   Sep 8 2010, 01:35 PM
- Lo-Fi Version Time is now: 15th June 2026 - 03:14 AM
