| orange914 |
Aug 20 2008, 11:29 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i am interested in the REAL world cost and issues incured by others who have built these motors. i recently finished one and so far am extreemly happy with how strong and smooth it runs. there where issues as with alot of things but after working thru them, all is well. my 2056 probably has a bit more done to it than most 2056 builds, that may account for the successful outcome BUT maybe not. from what i've seen this is a highly sucessful combination.
don't be shy and tell us what ALL was done and your detailed experiance with building/driving it. this could be a great help for past and present 2056 builds. if there is interest i'll make another poll on presures and temp.'s mike (IMG:style_emoticons/default/beerchug.gif) EDIT MCMARK: Added "No Problems" |
| Jake Raby |
Aug 23 2010, 06:10 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Funny this popped back up.. I am assembling a 2056 tonight, its the 160K mile engine that I tore down in this article on my site. I built this in 2002 for my personal 912E
http://www.aircooledtechnology.com/index.p...&Itemid=112 I am going back together with it almost exactly the same way, except with a new set of RS+ heads because the 2 liter castings were toast (as they ALWAYS are). I am actually going down on camshaft from a 9530 to a 9550 to better match the desires I have for the engine. I plan on posting the build up with all the used parts and a few new ones on my site.. The 160K mile KB pistons are even being reused! My goal is to only make the same power the engine made previously, around 130HP at the flywheel, I'd like to see 110 RWHP but at a lower RPM than previously, this is for my 30K+ mile per year daily driver that needs to average north of 35 MPG.. This post has been edited by Jake Raby: Aug 23 2010, 06:11 PM |
| realred914 |
Aug 24 2010, 09:39 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Funny this popped back up.. I am assembling a 2056 tonight, its the 160K mile engine that I tore down in this article on my site. I built this in 2002 for my personal 912E http://www.aircooledtechnology.com/index.p...&Itemid=112 I am going back together with it almost exactly the same way, except with a new set of RS+ heads because the 2 liter castings were toast (as they ALWAYS are). I am actually going down on camshaft from a 9530 to a 9550 to better match the desires I have for the engine. I plan on posting the build up with all the used parts and a few new ones on my site.. The 160K mile KB pistons are even being reused! My goal is to only make the same power the engine made previously, around 130HP at the flywheel, I'd like to see 110 RWHP but at a lower RPM than previously, this is for my 30K+ mile per year daily driver that needs to average north of 35 MPG.. so I take it you really like the KB piston? Just wondering what advantages do you find over some of the others from a technical stand point? is the material or build qulaity, piston design (combustion chamber, pin hieght, etc...) that makes the KB your choice? I understand they are forged, which should be a good thing strength wise. thanks for advice |
| Jake Raby |
Aug 25 2010, 11:07 AM
Funny this popped back up.. I am assembling a 2056 tonight, its the 160K mile engine that I tore down in this article on my site. I built this in 2002 for my personal 912E http://www.aircooledtechnology.com/index.p...&Itemid=112 I am going back together with it almost exactly the same way, except with a new set of RS+ heads because the 2 liter castings were toast (as they ALWAYS are). I am actually going down on camshaft from a 9530 to a 9550 to better match the desires I have for the engine. I plan on posting the build up with all the used parts and a few new ones on my site.. The 160K mile KB pistons are even being reused! My goal is to only make the same power the engine made previously, around 130HP at the flywheel, I'd like to see 110 RWHP but at a lower RPM than previously, this is for my 30K+ mile per year daily driver that needs to average north of 35 MPG.. so I take it you really like the KB piston? Just wondering what advantages do you find over some of the others from a technical stand point? is the material or build qulaity, piston design (combustion chamber, pin hieght, etc...) that makes the KB your choice? I understand they are forged, which should be a good thing strength wise. thanks for advice My pistons were in such good shape at 160K that I ended up reusing them for the new build. I simply blasted them with corn cob media and cleaned them up well. These were THE FIRST 96mm KB pistons that the company made, they were the prototypes! After all that time they measured out perfectly and had no scuffing or wear, you'll see pics in my "rebuild" thread over on my forums when I put it all together after the engine is on the dyno. The KB pistons are light, super strong and their composition makes them perfect for a hotter running aircooled engine, due to that we can run much tighter skirt clearances than with a JE, Mahle or etc. QUOTE As noted above, the heads can really bite you in the butt. Mine had cracks in the exhaust ports. The options are to have them repaired ($400 to $800) and hope the repair is done right and will last, buy 1.8 liter heads from AA for $950 each or buy new from Jake Raby. My heads were used up.. Len refused to do any work on them and I respected that. I just picked up my set of RS+ heads from him yesterday for the new engine. Head castings have a service life, people learn that when they TRY to reuse the castings again only to spend a ton of money and still have 30+ year old heads that are on their last leg. I can rebuild these new RS+ heads for the next 30 years as they are at the beginning of their service life. The only new parts I used in this engine was: camshaft (changed the profile) piston rings cylinder head assemblies main, rod and cam bearings rods (swapped out a set to save time) It'll go another 150K+, the crank has 260K on it now and still mic'd out to 2.1682 which is better than stock sizing with only a .0002 ovality between all 4 journals! Wait till you see the transformation I have given this baby with minimum expenditure. I have all new stuff 20 feet away, but I'd rather prove how robust the parts are for another 150K! |
| Don M |
Aug 26 2010, 07:25 AM
Newbie ![]() Group: Members Posts: 41 Joined: 22-August 09 From: California Member No.: 10,707 Region Association: None |
| Jake Raby |
Aug 26 2010, 08:53 AM
the crank has 260K on it now and still mic'd out to 2.1682 which is better than stock sizing with only a .0002 ovality between all 4 journals! is this right? seems to be o/s +.003 The variance in the stock crank sizes is more than .0045 This crank is one of the largest I have ever seen, especially with 260K miles on it. The numbers are correct. One of the links I posted was to my store site and the piston page.. The prices are there. QUOTE what is the new 2270 motor you now recommend over the 2056? Its not a general recommendation.. The 2056 is the largest that can safe;ly be supported by stock EFI. A 2270 is 78.4X96 so thats both bore and stroke. While the 2270 is my favorite engine in general and we do more with it than any other engine, in many instances it isn't the optimum combo, especially when stock EFI must be retained. I kept my engine a 2056 for a reason, because it was everything I wanted for my touring car/ full time driver to include 35+ MPG and reliability that most people simply don't believe the TIV can provide. QUOTE what is the cost for the pistons/cylinder set for the 2270 motor and can the 2270 be run with the 914 D-jet? They are in the link I provided as well.The 2270 should not be utilized with stock EFI, the results are very mixed and no guarantees of effectiveness can be made. Do lots more reading here, on the STF and on my forums, there are thousands of posts about the 2270. This post has been edited by Jake Raby: Aug 26 2010, 08:58 AM |
| Don M |
Aug 27 2010, 07:29 AM
The variance in the stock crank sizes is more than .0045 This crank is one of the largest I have ever seen, especially with 260K miles on it. The numbers are correct. seriously this is shocking, what your'e saying is that the OEM would supply a series of oversize bearings to accomodate this kind of screw up rather than correct the error. in 40 + years and 1000s of VW/Porsche cranks I've never seen or heard of this, got any part numbers or OEM tech info to support this? |
| Don M |
Aug 30 2010, 08:16 PM
The variance in the stock crank sizes is more than .0045 This crank is one of the largest I have ever seen, especially with 260K miles on it. The numbers are correct. seriously this is shocking, what your'e saying is that the OEM would supply a series of oversize bearings to accomodate this kind of screw up rather than correct the error. in 40 + years and 1000s of VW/Porsche cranks I've never seen or heard of this, got any part numbers or OEM tech info to support this? Jake, you say you are going rebuild so you must have some idea of a part number for the rod bearings to establish the correct clearance or perhaps whatever other method you use to set it up. |
| Jake Raby |
Aug 31 2010, 07:57 AM
The variance in the stock crank sizes is more than .0045 This crank is one of the largest I have ever seen, especially with 260K miles on it. The numbers are correct. seriously this is shocking, what your'e saying is that the OEM would supply a series of oversize bearings to accomodate this kind of screw up rather than correct the error. in 40 + years and 1000s of VW/Porsche cranks I've never seen or heard of this, got any part numbers or OEM tech info to support this? Jake, you say you are going rebuild so you must have some idea of a part number for the rod bearings to establish the correct clearance or perhaps whatever other method you use to set it up. A part number for a set of bearings isn't going to answer the question of actual running clearance. Running clearance MUST BE MEASURED with the components that you intend to install and these include the journal diameter of the crank as well as the rod bearing installed into the big end of the rod and torqued to spec. At this point a dial bore gauge is set up and standardized from the crankshaft rod journal and the running clearance is then possible to calculate. If the sizing of the big end of the rod, the thickness of the bearing and the diameter of the crank journal changes the actual running clearance will be impacted. See the Bentley manual for the allowable running clearance, ovality and journal diameters, its all there. Now, the engines may have been used for 40 years but variances in bearing manufacture, machined sizes of refinished parts and etc will always result in a need to measure running clearances for well built engines. In engine building you assume nothing and quantify everything, thats the first rule. The rod bearings I used for my build were my "2.0 Race Bearings". http://www.aircooledtechnology.com/store/p...=262&page=1 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircooledtechnology.com-1095-1283263055.1.jpg) I ended up with .0021 bearing clearance at maximum and .0019 minimum. These bearings are coated which alters my target running clearance.. I have the crank assembled for my engine and only await the time to set the rest of the clearances before sealing up the short block.. |
orange914 CALLING ALL 2056 engine owner/builders Aug 20 2008, 11:29 PM
Jake Raby I'll enter this one as an Enthusiast, not a pr... Aug 20 2008, 11:52 PM
orange914
I did our spark plug strengthening procedures to... Aug 21 2008, 01:54 AM
McMark My first 2056 was built with a set of AA pistons a... Aug 21 2008, 02:32 AM
orange914
My first 2056 was built with a set of AA pistons ... Aug 21 2008, 06:49 PM
sww914 My first 2056 is still my first 2056. I spent unde... Aug 21 2008, 02:53 AM
McMark Steve, are you aware that there is a fore/aft adju... Aug 21 2008, 03:23 AM
sww914
Steve, are you aware that there is a fore/aft adj... Aug 21 2008, 09:29 PM
Vacca Rabite I built mine over the winter of 2007. my only iss... Aug 21 2008, 08:06 AM
Jake Raby Orange,
The heads you picked up off me were not po... Aug 21 2008, 08:48 AM
azbill My 2056 was expensive because I bought an engine f... Aug 21 2008, 09:41 AM
Aircooledfool
My 2056 was expensive because I bought an engine ... Apr 1 2012, 10:27 AM
Jake Raby Bill, thats one hell of a lot of torque from a sto... Aug 21 2008, 10:07 AM
396 Great reading... now how does one come up with a 2... Aug 21 2008, 10:42 AM
Matt Meyer
Great reading... now how does one come up with a ... Aug 21 2008, 11:44 AM
Jake Raby Follow the 1.7/ 1.8 >> 2.0 conversion articl... Aug 21 2008, 11:10 AM
396
Follow the 1.7/ 1.8 >> 2.0 conversion artic... Aug 21 2008, 01:59 PM
scottb my 2056 was expensive (>$7000) because i f... Aug 21 2008, 11:32 AM
pete-stevers i have never built one...but follow this engines t... Aug 21 2008, 11:49 AM
Joe Ricard I guess it all depends on what you want to spend o... Aug 21 2008, 11:51 AM
Al Meredith I built a 2056 about two years ago. It is in my 91... Aug 21 2008, 08:15 PM
McMark
IIRC, I got them for $500 when they were ava... Aug 21 2008, 09:07 PM
Vacca Rabite Hahaha! Someone necro-polled!
And I jus... Aug 22 2010, 06:26 PM
DanT mine was easy...
under $3K
no issues during b... Aug 22 2010, 07:36 PM
realred914
i am interested in the REAL world cost and issues... Aug 23 2010, 08:55 AM
orange914
[quote name='orange914' post='1069559' date='Aug ... Aug 23 2010, 06:46 PM
realred914
[quote name='orange914' post='1069559' date='Aug... Aug 24 2010, 09:32 AM
Bleyseng I can tell you mine..
Raby supplied 96mm J&E p... Aug 23 2010, 09:06 AM
realred914 Great thanks for the details!!!!... Aug 23 2010, 09:15 AM
Bleyseng The "Best" way is to reuse your 94mm cyl... Aug 23 2010, 09:24 AM
realred914
The "Best" way is to reuse your 94mm cy... Aug 23 2010, 09:28 AM
Vacca Rabite I have heard bad things about the AA sets for high... Aug 23 2010, 04:52 PM
Don M
A part number for a set of bearings isn't goi... Aug 31 2010, 06:48 PM
realred914
[quote name='Don M' post='1361437' date='Aug 26 2... Aug 27 2010, 09:21 AM
JimN73 I'm going thru a 2056 rebuild right now, the o... Aug 24 2010, 09:56 AM
scotty b Jake, what are the limitations with stock 2.0 inje... Aug 25 2010, 09:13 AM
Cevan My cost was about $3000 total to rebuild a 2.... Aug 25 2010, 12:14 PM
realred914
My cost was about $3000 total to rebuild a 2... Aug 25 2010, 11:26 PM
Jake Raby
http://www.aircooledtechnology.com/store/home.php... Aug 26 2010, 01:04 AM
realred914
http://www.aircooledtechnology.com/store/home.ph... Aug 26 2010, 08:50 AM
Jake Raby Nope, no O/S or U/S bearings were used or availabl... Aug 31 2010, 07:06 PM
Don M
Nope, no O/S or U/S bearings were used or availab... Sep 1 2010, 09:07 PM
Jake Raby
Nope, no O/S or U/S bearings were used or availa... Sep 2 2010, 08:44 AM
realred914
[quote name='Don M' post='1364840' date='Sep 1 20... Sep 2 2010, 09:48 AM
Don M I finished the big end of the rods to the size nec... Sep 2 2010, 09:52 PM
realred914 still tyring to get the answer Jake: are you usin... Sep 2 2010, 08:06 AM
Bleyseng Ahh, its just some fancy Snake Oil...... Sep 2 2010, 09:10 AM
Jake Raby
Exactl... Sep 2 2010, 09:29 AM
Bleyseng I thought it was quite funny when I first saw it..... Sep 2 2010, 03:15 PM
pete-stevers Geoff...when are you guys coming back for a visit?... Sep 2 2010, 03:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:45 AM |
