> 15 years in storage - Paint Code pic added
budk
post Aug 30 2010, 07:28 PM
Yes! It's a Bumblebee!
I just brought home a 74 2.0 that was last run in 1995.
Supposedly it was running and had a fuel pump problem and it was parked and not touched since.
I'm looking for suggestions as to where to start. I'd like to get a handle on the condition of the engine first so I'm looking for suggestions.
Opinions are be appreciated.
Pics (bad pics) are farther down in this thread.
Tom_T
post Aug 31 2010, 10:36 AM
TMI....
All good advice above - don't run the motor until you go through & replace all fuel system lines, etc. - ditto on the brake system.
IMHO - POR15 & similar products just covers up the problems with rust if it hasn't been cut out, converted & replaced with good sheet metal or panels (see Restoration Design for replacement panels). Even if not a Bee, it looks to be in great shape & well worth fixing any rust damage properly to get another 40 years out of her!
See the LE info here - it ma be on the registry -
http://www.bowlsby.net/914/CanAm/
budk
post Aug 31 2010, 11:10 AM
QUOTE(Tom_T @ Aug 31 2010, 12:36 PM) *
It's tough to live in the East and not have some rust issue to deal with on a constant basis. I plan on using por15 on any surface rust that I can, but if I run into a bigger issue it will be time to cut and replace.
The CanAm site is the first place I looked. It's not listed there ... not yet anyway.
Thanks.
strawman
post Aug 31 2010, 11:28 AM
QUOTE(budk @ Aug 31 2010, 10:10 AM) *
I am nearing the end of the rustoration of my CA car (they ALL rust if exposed to the elements!), and I agree that proper prep and conversion works best for surface rust / minor pitting and that replacement panels are necessary for rust-through / major pitting. But I don't agree that you'll need to replace EVERY panel that has evidence of rust... these tubs were not galvanized from the factory and I frankly believe that it would be impossible to truly eradicate all rust and/or prevent it completely. There are just too many nooks/crannies/seams to get at it all...
Good luck with your project. In hindsight, I really shoulda started with a cleaner tub.
Geoff
budk   15 years in storage - Paint Code pic added   Aug 30 2010, 07:28 PM
mepstein   Ask your bank about a second mortgage. Check the...   Aug 30 2010, 07:42 PM
SirAndy   what should I do first? Post pictures here! :...   Aug 30 2010, 07:46 PM
tornik550   I think that I should chime in and say that the ca...   Aug 30 2010, 08:05 PM
jt914-6   Clean out the mice nests/mess and check for wiring...   Aug 30 2010, 08:54 PM
SLITS   :agree: Remove the rack access panel on the bott...   Aug 30 2010, 09:08 PM
Tom_T   :wttc: .... to all y'uns from a former PGHer...   Aug 30 2010, 10:46 PM
budk   Thanks for all the good input. It's certainly...   Aug 31 2010, 03:46 AM
swl   I understand the concern that a fuel pump should...   Aug 31 2010, 04:54 AM
Tom_T   How to post pix here - http://www.914world.com/bbs...   Aug 31 2010, 03:50 AM
Bleyseng   just post alot of pics so we can advise you :popco...   Aug 31 2010, 03:51 AM
budk   SWL - thanks - i am thinking along the same lines....   Aug 31 2010, 05:22 AM
swl   Now you're talking Bud! Any guy who's...   Aug 31 2010, 05:44 AM
914Sixer   What is the VIN number? It looks like it maybe a ...   Aug 31 2010, 06:27 AM
budk   What is the VIN number? It looks like it maybe a...   Aug 31 2010, 06:34 AM
nsr-jamie   penetrating fluid for a few days should help too i...   Aug 31 2010, 06:39 AM
ME733   .......THE VERY FIRST THING to do is to rebuild th...   Aug 31 2010, 07:12 AM
budk   .......THE VERY FIRST THING to do is to rebuild t...   Aug 31 2010, 07:25 AM
Krieger   To be fully confident I would consider going throu...   Aug 31 2010, 07:50 AM
budk   To be fully confident I would consider going thro...   Aug 31 2010, 07:55 AM
dlee6204   Before you do ANYTHING, you should sit in the driv...   Aug 31 2010, 08:53 AM
markb   Before you do ANYTHING, you should sit in the dri...   Aug 31 2010, 01:08 PM
tornik550   I am absolutely convinced that this is a bumblebee...   Aug 31 2010, 09:02 AM
rick 918-S   :wttc: :smash: :sawzall: :welder:   Aug 31 2010, 09:10 AM
Bristol   I would do what others have recommended on thoroug...   Aug 31 2010, 09:32 AM
underthetire   I would do what others have recommended on thorou...   Aug 31 2010, 04:30 PM
Tom_T   All good advice above - don't run the motor un...   Aug 31 2010, 10:36 AM
budk   All good advice above - don't run the motor u...   Aug 31 2010, 11:10 AM
strawman   It's tough to live in the East and not have ...   Aug 31 2010, 11:28 AM
SirAndy   I plan on using por15 on any surface rust that I c...   Aug 31 2010, 04:08 PM
Rav914   When I bought my '74, it had been 'stored...   Aug 31 2010, 10:57 AM
Dr Evil   Score, the guy who bought the car is a neighbor :t...   Aug 31 2010, 12:27 PM
budk   Score, the guy who bought the car is a neighbor :...   Aug 31 2010, 12:48 PM
Dr Evil   20 min away with a nice car to start with. There i...   Aug 31 2010, 12:54 PM
budk   20 min away with a nice car to start with. There ...   Aug 31 2010, 01:37 PM
Tom_T   20 min away with a nice car to start with. There ...   Aug 31 2010, 07:00 PM
RFoulds   I am doing the same thing. Mine was in storage 22...   Aug 31 2010, 01:29 PM
Rod   First thing you should do is pull up a deck chair,...   Aug 31 2010, 04:33 PM
windforfun   First thing you should do is pull up a deck chair...   Aug 31 2010, 05:40 PM
scotty b   Do yourself a favor and spend the money to have th...   Aug 31 2010, 05:51 PM
Ian Stott   I have a 73 2.0 and it had been stored for quite s...   Aug 31 2010, 06:48 PM
jsayre914   Hey Bud, I just noticed you work for the departmen...   Aug 31 2010, 07:03 PM
budk   Hey Bud, I just noticed you work for the departme...   Aug 31 2010, 08:20 PM
faux916   Good Score Bud! I will email you when I get so...   Aug 31 2010, 07:25 PM
budk   Dr. Evil is coming tonight so I should have a litt...   Sep 2 2010, 08:03 AM
Tom_T   Dr. Evil is coming tonight so I should have a lit...   Sep 2 2010, 02:33 PM
budk   Lot's done to the car this past weekend. Gas...   Sep 7 2010, 07:51 AM
siverson   > I'm looking for suggestions as to where t...   Sep 7 2010, 06:47 PM
budk   > I'm looking for suggestions as to where ...   Sep 8 2010, 07:36 AM
type47   Send you engine cooling tin and intake runners and...   Sep 8 2010, 01:35 PM
- Lo-Fi Version Time is now: 15th June 2026 - 03:17 AM
