| trent1542 |
Sep 1 2010, 09:05 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 19-August 10 Member No.: 12,074 Region Association: Pacific Northwest |
what is the difference between Djet and Ljet F.I.
And what would be better if I want to restore my '70 1.7L/4 to stock. sorry for the terrible question (IMG:style_emoticons/default/newhere.gif) |
| dr914@autoatlanta.com |
Sep 1 2010, 09:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,240 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
what is the difference between Djet and Ljet F.I. And what would be better if I want to restore my '70 1.7L/4 to stock. sorry for the terrible question (IMG:style_emoticons/default/newhere.gif) TO STOCK means d jet. (MPC) L jet (AFC) is the superior system and much simpler than the d, but was only available on the 74 75 1.8 and 2.0 912e models. The systems are totally different one using an air flow meter and the other using a manifold pressure sensor, for starters! |
| trent1542 |
Sep 1 2010, 09:27 AM
TO STOCK means d jet. (MPC) L jet (AFC) is the superior system and much simpler than the d, but was only available on the 74 75 1.8 and 2.0 912e models. The systems are totally different one using an air flow meter and the other using a manifold pressure sensor, for starters! Is Ljet more reliable too? I want a system that will last long on my 1.7. |
Sep 1 2010, 09:30 AM
Yes. Because of its simplicity, L jet IS more reliable. One needs to watch the air flow meter for lean backfire when starting cold, and keep the dual relay clean, but beyond that it is great.
The caveat is that since the system was only made for two years and that 75 adn 74 are slightly different (seven pin vs six pin air box and harness) that finding used parts for the system would be hard. TO STOCK means d jet. (MPC) L jet (AFC) is the superior system and much simpler than the d, but was only available on the 74 75 1.8 and 2.0 912e models. The systems are totally different one using an air flow meter and the other using a manifold pressure sensor, for starters! Is Ljet more reliable too? I want a system that will last long on my 1.7. |
| trent1542 |
Sep 1 2010, 09:50 AM
Yes. Because of its simplicity, L jet IS more reliable. One needs to watch the air flow meter for lean backfire when starting cold, and keep the dual relay clean, but beyond that it is great. The caveat is that since the system was only made for two years and that 75 adn 74 are slightly different (seven pin vs six pin air box and harness) that finding used parts for the system would be hard. Thanks (IMG:style_emoticons/default/biggrin.gif) Now I need to get this project (IMG:style_emoticons/default/driving.gif) |
trent1542 Djet vs Ljet Sep 1 2010, 09:05 AM
realred914
Yes. Because of its simplicity, L jet IS more r... Sep 2 2010, 09:54 AM
Als914
Yes. Because of its simplicity, L jet IS more r... Sep 2 2010, 12:40 PM
Root_Werks There is a ton of good information on both D-Jet a... Sep 1 2010, 09:58 AM
trent1542 what about Ljet vs dual weber carbs?
or just F.I. ... Sep 1 2010, 10:10 AM
dr914@autoatlanta.com Forget the carbs!!! Remember you star... Sep 1 2010, 10:50 AM
76-914
or just F.I.... Sep 2 2010, 08:46 AM
type47 I would suggest instead of spending money to get a... Sep 1 2010, 10:32 AM
johannes
I would suggest instead of spending money to get ... Sep 1 2010, 10:46 AM
Marty Yeoman L-Jet was also installed on VW bugs and Vans (not ... Sep 1 2010, 01:33 PM
Bleyseng
L-Jet was also installed on VW bugs and Vans (not... Sep 2 2010, 03:39 AM
trent1542 thanks guys I'm gonna stick to djet for now. :... Sep 1 2010, 04:16 PM
RFoulds my take on carbs vs. FI in a 914. Carbs for serio... Sep 1 2010, 05:10 PM
trent1542
my take on carbs vs. FI in a 914. Carbs for seri... Sep 1 2010, 05:52 PM
Vacca Rabite Carbs have thier place in the 914 world, but that ... Sep 1 2010, 06:32 PM
Cevan D-Jet was phasing out at the same time L-Jet was b... Sep 2 2010, 06:29 AM
Marty Yeoman I think the seventh pin is a ground. Sep 2 2010, 01:06 PM
sean_v8_914 seventh pin is another temp sensor in teh air box Sep 2 2010, 08:30 PM
trent1542 My thread has been hijacked by Als914! Lol :D Sep 2 2010, 09:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:45 AM |
