| bmtrnavsky |
Sep 1 2010, 12:23 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
I was driving home last night and my low beam headlights stopped working. High beams come on normal and all the other lights work. Fuses are all good. Ideas? (IMG:style_emoticons/default/confused24.gif)
| anderssj |
Sep 1 2010, 12:48 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,792 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
I had this problem about 5 years ago on my 72.
If I remember correctly, the fact that the fog lights and high beams work indicates the headlight switch is OK. The problem would have to be with either the connections leading to/from the combination relay or internal to the combination relay itself. IIRC, it's a rectangular relay on the fuse panel (I think). On my 72, the relay is powered through the red/white wire between "56" on headlight switch and "56" on the combination relay--your 73 might be different. In my case, the problem was internal to the relay--the low beam contacts weren't staying closed. I opened the relay and cleaned up the contacts (and maybe tweeked the spring/tensioner a little) and it's been good since. Sorry, I don't have pictures . . . . Hope this helps. Steve A- |
bmtrnavsky Low beam headlights not working. Sep 1 2010, 12:23 PM
bmtrnavsky
I was driving home last night and my low beam hea... Sep 1 2010, 12:28 PM
vsg914 Did you try rolling the fuse in it holder? Sep 1 2010, 12:30 PM
dr914@autoatlanta.com Hi Low beam relay has failed. Typical
I was d... Sep 1 2010, 12:38 PM
bmtrnavsky
I was ... Sep 1 2010, 12:40 PM
bmtrnavsky
I... Sep 1 2010, 04:44 PM
avidfanjpl Relay is behind the fuse panel. 2 screws or bolts ... Sep 1 2010, 05:52 PM
Vacca Rabite 1) unhook the battery.
2) drop the fuse panel in c... Sep 1 2010, 06:36 PM
bmtrnavsky
2) drop the fuse panel in ... Sep 2 2010, 12:52 AM
windforfun
2) drop the fuse panel in... Sep 2 2010, 11:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:31 AM |
