| Krieger |
Sep 2 2010, 07:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,862 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Last night I woke up thinking of a second redundant hydyraulic system for the rear brakes only. Perhaps a T-1 master, or some small slave cylinder attatched to a handle that could apply force for braking....Then I says to myself "self you could plumb this into the existing line going to the rear of the car and put a one way valve in that line to keep it pumping the rears only" Also a one way valve would be need to protect the e-brake pump from the main master cylinder. I know a cable is the ultimate redundant system, but this could be a cool compromise keeping complexity/weight/junk off those rear wheels. (IMG:style_emoticons/default/first.gif) or : (IMG:style_emoticons/default/stromberg.gif)
(IMG:style_emoticons/default/popcorn[1].gif) |
| jmill |
Sep 2 2010, 09:34 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
If you want a true E brake then the last thing you want to do is plumb it into the existing line. A ruptured line = no brakes. Mechanical is the only way to go if you want to stop in an emergency. I've had all kinds of failures from ruptured lines, failed master cylinders, leaking pistons and pads ripping out of the calipers. Without a mechanical back-up I wouldn't be here typing this.
Krieger New idea for e-brake? Sep 2 2010, 07:43 AM
Mark Henry
Last night I woke up thinking of a second redunda... Sep 2 2010, 07:46 AM
PH1
Can the mechanical brake be on the front? Sep 2 2010, 10:55 PM
Eric_Shea Hot brakes and fluid (what they are when you usual... Sep 2 2010, 08:21 AM
76-914 Mark's right, but if you must.......... http... Sep 2 2010, 08:23 AM
kg6dxn I'm running one of these. the PO gutted the pa... Sep 2 2010, 08:40 AM
Krieger Damn I thought I came up with a new Flux Capacitor... Sep 2 2010, 08:56 AM
davep Federal law requires a functional, and mechanical,... Sep 2 2010, 11:39 AM
McMark Don't some people use a 'line lock' to... Sep 2 2010, 01:10 PM
SirAndy Don't some people use a 'line lock' to... Sep 2 2010, 01:18 PM
messix
Don't some people use a 'line lock' t... Sep 2 2010, 11:30 PM
Sleepin Is a wood block mechanical enough? :lol: Sep 2 2010, 01:45 PM
McMark NEVER use a wood block. The appropriate tool is a... Sep 2 2010, 01:55 PM
MoveQik
NEVER use a wood block. The appropriate tool is ... Sep 3 2010, 12:57 AM
Sleepin That also doubles as an "Emergency Entrance D... Sep 2 2010, 02:04 PM
sixnotfour I am suprised Troy didnt mention this setup , old ... Sep 2 2010, 11:42 PM
messix
I am suprised Troy didnt mention this setup , old... Sep 3 2010, 12:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:41 AM |
