> CALLING ALL 2056 engine owner/builders, survey for past AND future 2056 builders
survey for past 2056 builders
how much was final cost?
UNDER $2000 [ 9 ] ** [16.36%]
UNDER$3000 [ 16 ] ** [29.09%]
UNDER $4000 [ 8 ] ** [14.55%]
UNDER $5000 [ 10 ] ** [18.18%]
UNDER $6000 [ 7 ] ** [12.73%]
UNDER $7000 [ 2 ] ** [3.64%]
OVER $7000 [ 3 ] ** [5.45%]
what problem/issues did you have during build
BOTTOM END case/cam/crank/rods [ 3 ] ** [5.45%]
P&C'S [ 7 ] ** [12.73%]
HEADS [ 3 ] ** [5.45%]
FUEL/EXHAUST [ 0 ] ** [0.00%]
MORE THAN 1 AREA [ 5 ] ** [9.09%]
No problems [ 37 ] ** [67.27%]
what problem/issues did you have AFTER engine break in
BOTTOM END [ 2 ] ** [3.64%]
P&C'S [ 2 ] ** [3.64%]
HEADS [ 4 ] ** [7.27%]
FUEL/EXHAUST [ 8 ] ** [14.55%]
MORE THAN 1 AREA [ 2 ] ** [3.64%]
Total Votes: 165
Guests cannot vote
orange914
post Aug 20 2008, 11:29 PM
http://5starmediaworks.com/index.html
i am interested in the REAL world cost and issues incured by others who have built these motors. i recently finished one and so far am extreemly happy with how strong and smooth it runs. there where issues as with alot of things but after working thru them, all is well. my 2056 probably has a bit more done to it than most 2056 builds, that may account for the successful outcome BUT maybe not. from what i've seen this is a highly sucessful combination.
don't be shy and tell us what ALL was done and your detailed experiance with building/driving it. this could be a great help for past and present 2056 builds.
if there is interest i'll make another poll on presures and temp.'s
mike (IMG:style_emoticons/default/beerchug.gif)
EDIT MCMARK: Added "No Problems"
Jake Raby
post Aug 31 2010, 07:06 PM
Engine Surgeon
Nope, no O/S or U/S bearings were used or available.. The variances simply resulted in more or less running clearance because the tolerances are so open... Check out Bentley..
The stock engine is a fairly grossly toleranced unit, look at the tolerance for balance between a set of pistons, or a set of rods.. Its absurd, the same goes with tolerances for runing clearances.
Thats why the engines wake up and run so much better when properly blueprinted and assembled, hell when Blake made 130+HP from a bone stock 2.0 engine and people wonder why, this is exactly why... Control of critical tolerances.
can't see what plating/coating a std bearing is going to do to solve this situation
You missed the point.. We coat bearings for a totally different purpose, to assist with oil retention between the bearing and the journal, not to hone clearances. When this is done the bearing coating takes up some of the clearance, generally .0005" so that has to be considered during the journal sizing.
My numbers just happen to have come out exactly where I wanted them with my very large crank diameters for the weight of oil that I intend to run and RPM that the engine will be used for.
If I ever need to set a clearance to a specific number and the components I have don't add up to that size, we then have to go a full .010 under size, then measure that bearing installed into the big end of the rod and have the crank cut to that specific diameter.. Usually doing this requires the micrometer that was used to set the bore gauge with the crank so that specific tool can be used to measure the journal diameter for absolute accuracy.
Its a bitch.
This post has been edited by Jake Raby: Aug 31 2010, 07:14 PM
Don M
post Sep 1 2010, 09:07 PM
QUOTE(Jake Raby @ Aug 31 2010, 06:06 PM) *
Jake,
Bentley is of no value in this situation.. wear limits do not apply here unless you plan to exceed recommended housing bore sizes (very bad idea) or run used/worn bearings...all booked bearing specs, using max rod bore and min shell thickness show an interference fit on a 2.1682" journal dia. and that's without allowing for proper crush on the inserts. if you don't mind sharing... what size did you finish the big end of the rods to?
Jake Raby
post Sep 2 2010, 08:44 AM
Engine Surgeon
QUOTE(Don M @ Sep 1 2010, 08:07 PM) *
Jake,
I finished the big end of the rods to the size necessary to attain the running clearance I was looking for with the bearings that were being used. In this situation it was at split low tolerance by the book.
still tyring to get the answer Jake: are you using yoru own mix of oil now rather than the bradPenn, if so, what is the difference you see? or is the snake oil not real? cant tell if it is a joke or what?
I have answered this question 3 times in this thread already.
We are using our own lubricant now and have been for a good while. The Brad Penn remains the only authorized oil other than our own for our engines.
Unless Brad Penn changes it will remain an authorized oil for my engines and kits. Until last week we still had some of our fleet of cars running Brad Penn, now all my cars and my employees cars are running our oil.
The oil IS NOT A JOKE. The break in oil is pour most developed product as of now, it will be the first oil that we begin to market to the public, at a time yet TBD.
realred914
post Sep 2 2010, 09:48 AM
Group: Retired Members
QUOTE(Jake Raby @ Sep 2 2010, 07:44 AM) *
Jake,
ok that clears it up, thanks, the labling and all made it appear to me to be a joke, sure is funny. thnaks!
orange914   CALLING ALL 2056 engine owner/builders   Aug 20 2008, 11:29 PM
Jake Raby   I'll enter this one as an Enthusiast, not a pr...   Aug 20 2008, 11:52 PM
orange914   I did our spark plug strengthening procedures to...   Aug 21 2008, 01:54 AM
McMark   My first 2056 was built with a set of AA pistons a...   Aug 21 2008, 02:32 AM
orange914   My first 2056 was built with a set of AA pistons ...   Aug 21 2008, 06:49 PM
sww914   My first 2056 is still my first 2056. I spent unde...   Aug 21 2008, 02:53 AM
McMark   Steve, are you aware that there is a fore/aft adju...   Aug 21 2008, 03:23 AM
sww914   Steve, are you aware that there is a fore/aft adj...   Aug 21 2008, 09:29 PM
Vacca Rabite   I built mine over the winter of 2007. my only iss...   Aug 21 2008, 08:06 AM
Jake Raby   Orange, The heads you picked up off me were not po...   Aug 21 2008, 08:48 AM
azbill   My 2056 was expensive because I bought an engine f...   Aug 21 2008, 09:41 AM
Aircooledfool   My 2056 was expensive because I bought an engine ...   Apr 1 2012, 10:27 AM
Jake Raby   Bill, thats one hell of a lot of torque from a sto...   Aug 21 2008, 10:07 AM
396   Great reading... now how does one come up with a 2...   Aug 21 2008, 10:42 AM
Matt Meyer   Great reading... now how does one come up with a ...   Aug 21 2008, 11:44 AM
Jake Raby   Follow the 1.7/ 1.8 >> 2.0 conversion articl...   Aug 21 2008, 11:10 AM
396   Follow the 1.7/ 1.8 >> 2.0 conversion artic...   Aug 21 2008, 01:59 PM
scottb   my 2056 was expensive (>$7000) because i f...   Aug 21 2008, 11:32 AM
pete-stevers   i have never built one...but follow this engines t...   Aug 21 2008, 11:49 AM
Joe Ricard   I guess it all depends on what you want to spend o...   Aug 21 2008, 11:51 AM
Al Meredith   I built a 2056 about two years ago. It is in my 91...   Aug 21 2008, 08:15 PM
McMark   IIRC, I got them for $500 when they were ava...   Aug 21 2008, 09:07 PM
Vacca Rabite   Hahaha! Someone necro-polled! And I jus...   Aug 22 2010, 06:26 PM
DanT   mine was easy... under $3K no issues during b...   Aug 22 2010, 07:36 PM
realred914   i am interested in the REAL world cost and issues...   Aug 23 2010, 08:55 AM
orange914   [quote name='orange914' post='1069559' date='Aug ...   Aug 23 2010, 06:46 PM
realred914   [quote name='orange914' post='1069559' date='Aug...   Aug 24 2010, 09:32 AM
Bleyseng   I can tell you mine.. Raby supplied 96mm J&E p...   Aug 23 2010, 09:06 AM
realred914   Great thanks for the details!!!!...   Aug 23 2010, 09:15 AM
Bleyseng   The "Best" way is to reuse your 94mm cyl...   Aug 23 2010, 09:24 AM
realred914   The "Best" way is to reuse your 94mm cy...   Aug 23 2010, 09:28 AM
Vacca Rabite   I have heard bad things about the AA sets for high...   Aug 23 2010, 04:52 PM
Jake Raby   Funny this popped back up.. I am assembling a 2056...   Aug 23 2010, 06:10 PM
realred914   Funny this popped back up.. I am assembling a 205...   Aug 24 2010, 09:39 AM
Jake Raby   [quote name='Jake Raby' post='1360279' date='Aug ...   Aug 25 2010, 11:07 AM
Don M   the crank has 260K on it now and still mic'd o...   Aug 26 2010, 07:25 AM
Jake Raby   the crank has 260K on it now and still mic'd ...   Aug 26 2010, 08:53 AM
Don M   The variance in the stock crank sizes is more tha...   Aug 27 2010, 07:29 AM
Don M   The variance in the stock crank sizes is more th...   Aug 30 2010, 08:16 PM
Jake Raby   [quote name='Don M' post='1361949' date='Aug 27 2...   Aug 31 2010, 07:57 AM
Don M   A part number for a set of bearings isn't goi...   Aug 31 2010, 06:48 PM
realred914   [quote name='Don M' post='1361437' date='Aug 26 2...   Aug 27 2010, 09:21 AM
JimN73   I'm going thru a 2056 rebuild right now, the o...   Aug 24 2010, 09:56 AM
scotty b   Jake, what are the limitations with stock 2.0 inje...   Aug 25 2010, 09:13 AM
Cevan   My cost was about $3000 total to rebuild a 2....   Aug 25 2010, 12:14 PM
realred914   My cost was about $3000 total to rebuild a 2...   Aug 25 2010, 11:26 PM
Jake Raby   http://www.aircooledtechnology.com/store/home.php...   Aug 26 2010, 01:04 AM
realred914   http://www.aircooledtechnology.com/store/home.ph...   Aug 26 2010, 08:50 AM
Jake Raby   Nope, no O/S or U/S bearings were used or availabl...   Aug 31 2010, 07:06 PM
Don M   Nope, no O/S or U/S bearings were used or availab...   Sep 1 2010, 09:07 PM
Jake Raby   Nope, no O/S or U/S bearings were used or availa...   Sep 2 2010, 08:44 AM
realred914   [quote name='Don M' post='1364840' date='Sep 1 20...   Sep 2 2010, 09:48 AM
Don M   I finished the big end of the rods to the size nec...   Sep 2 2010, 09:52 PM
realred914   still tyring to get the answer Jake: are you usin...   Sep 2 2010, 08:06 AM
Bleyseng   Ahh, its just some fancy Snake Oil......   Sep 2 2010, 09:10 AM
Jake Raby   Ahh, its just some fancy Snake Oil...... Exactl...   Sep 2 2010, 09:29 AM
Bleyseng   I thought it was quite funny when I first saw it.....   Sep 2 2010, 03:15 PM
pete-stevers   Geoff...when are you guys coming back for a visit?...   Sep 2 2010, 03:47 PM
- Lo-Fi Version Time is now: 15th June 2026 - 03:25 AM
